LinkBack Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 06-18-2012, 06:36 PM
Cobra Make, Engine: Factory Five, 302
Default Got towed home yesterday need engine help
I took a long drive yesterday in the Cobra and it was running well until I was almost to the restaurant. As I pulled out from a stop sign it hesitated slightly and then smoothed out for another mile or so. At the next turn it bogged down pretty bad as I accelerated. I made it to the restaurant, but had to get towed home after that. It still runs, but idles roughly and the tachometer bounces between 600-900. Every few seconds the tachometer jumps to almost 2000 without any change in the idle. I have an Explorer motor with a Holley 570 and Max fire distributor. The setup has about 1800 miles and has worked perfectly until now. I've checked the following without seeing anything wrong.
1. I inspected the three and two pin connector at the Mallory Max fire.
2. I removed the cap and top cover of the distributor and inspected the cap, rotor and PCB.
3. Removed the tachometer signal wire at the distributor and started the engine. The tachometer still bounce some although the signal wire was disconnected. Power and ground was still connected.
The engine runs and idles, but it is rough although it smooths out for a few seconds every now and then. Does anyone have a suggestion of where I should look next? Thanks for the help.
Jeff
Old 06-18-2012, 07:45 PM
WardL's Avatar
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
Just so you don't do a lot of work before checking, you ight check to see your fuel doesn't have too much water. If the fuel is cloudy, it is bad. Ethanol in the fuel (E10)will soak up much more water than fuel with no ethanol (E0) and run fine. But everything has a limit and when too much water gets into your gasoline, the water starts to drop out and settle to the bottom of your gas tank. Cloudy fuel or fuel with little dropplets is the best indicator of a problem. The water is heavier and sits on the bottom of the gasoline.
Old 06-19-2012, 01:20 AM
Caprimaniac's Avatar
Cobra Make, Engine: Unfortunataly ; none
The MAX fire does have some circuitry in the cap? Maybe some ghosts there? Have a look at the instructions, maybe there's a way to test the dist.
Might be fuel realted as well... Floats or other.
Old 06-19-2012, 03:09 AM
Gaz64's Avatar
A faulty tachometer will cause your issue, especially if the needle still moves with the signal wire disconnected.
Don't discount a tachometer as the cause for intermittent spark.
Gary
Old 06-19-2012, 04:51 AM
The tachometer needle does bounce around with the engine running even though the signal wire is disconnected. I keep thinking the tachometer is a clue, but without a direct connection to the distributor I don't see why. It is an electronic tach from Speed Hut. The engine still runs rough with the signal wire disconnected.
Old 06-19-2012, 04:55 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Remember the three 'F's.
Fuel
Fire
Function
Check for each.
Old 06-19-2012, 07:18 PM
Default Update
I didn't have much time tonight, but I checked the resistance of the coil (less than 1ohm) and looked at connections again. I started it and it was more difficult then usual, but did start and idle roughly. I let it idle for a minute or two and shut off all the lights in the garage to see if anything was arcing or sparking. I didn't see anything so I gave it some gas. Within about 20 seconds it backfired out the pipes and stopped running. I tried to start it again, but no dice. It will fire for a split second if I pump the gas, but that's it. I have a hard fail of something at this point, but no more time to work on it tonight. I'll look more tomorrow.
So far I've avoided removing the distributor to check the gear for a reason. My damper doesn't have any timing marks on it so it's hard to get it timed correctly. The last time it was set on the dyno by my tuner. I think I'm getting very close to either doing that or buying another coil. I hate troubleshooting by shotgunning parts. I talked to Mallory and they said they would test the distributor for free, but it would take 2 to 3 weeks. If I pull it I may send it to them for testing. I have a few other things to check before I do that.
Jeff
Old 06-20-2012, 03:18 AM
Gaz64's Avatar
Jeff
This may be a silly question, why has the engine got no timing marks?
Who built the engine without reliable timing marks?
How did the tuner know what timing the engine is running?
Did he alter the timing while plotting for max torque through the useable rpm band?
Remove the rotor button and check there is no carbon tracking where it goes on the shaft.
Gary
Old 06-20-2012, 06:10 AM
The motor is from a low mileage Explorer from a salvage yard. I bought a new damper and many other components to convert it to a Mustang front dress and carb. The damper was from Ford Racing and had very light indents in the finish that I used to set timing to get it started. They were extremely hard to see so I bought one of those tapes and installed it. Before I put the tape on I wiped the damper with acetone to clean it and what marks that were there disappeared. The tuner adjusted the timing on the dyno and I'm not sure exactly how he did it, but it seemed pretty good for the first 1800 miles. I've had the rotor off already, but will remove it again to look closer. Thanks
Old 06-19-2012, 10:12 PM
WardL's Avatar
When was the last time you gassed up?
Old 06-20-2012, 06:03 AM
Last Thursday
Old 06-20-2012, 06:09 AM
Cobra Make, Engine: EM
Please understand that I am by no means an expert.
However, I just resolved a problem similar to yours.
It turn out to be a bad coil.
When checking to see if you have spark do it in a dark garage to make sure it is blue not yellow. Also crank the engine for several seconds to make sure you continue to get good spark. This turned out to be my issue. The spark was weak and after a few seconds I did not get any spark at all.
Again, I'm just a hobbyist so take this for what it worth.
Roger
Old 06-20-2012, 06:13 AM
Roger
How exactly do I do this? do I only need to remove one plug and crank it over with all the other plugs installed and connected or do I need to disconnect all the other plugs to keep it from starting(assuming it might start)?
Jeff
Old 06-21-2012, 04:20 AM
Cobra Make, Engine: backdraft racing #470 427sb
Jeff
Go to Napa or any parts store and ask for an inline spark tester! Lot safer! The last thing you want is to have the fuel vapor pushed out the empty spark plug hole and light with a plug open to the vapors. Just a thought on the safe side, you wouldn't be the first guy to burn down his garage. Tim
Old 06-20-2012, 05:50 AM
Try replacing the rotor or at least check to see if it is working. Make sure that your coil is working and then check to see if you are getting fire to the plugs. I have had 3 go bad before. Two Fords and one Chevy.
Just a thought.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 06-20-2012, 06:24 AM
I'll tell you what I did, but it would be wise to verify my technique with some of the more experienced people here on Clubcobra.
I removed one plug and let it lie on the intake manifold so the plug would be grounded. I tested the manifold with my volt meter and it was grounded.
The other plugs were left intact. I also took a video of the plug while I was doing the test so I could get feedback from other members.
It took me several days to track down my problem.... frustrating at times, but it was a great learning experience.
Old 06-29-2012, 09:59 AM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Default coil
Hi,
1st- Do you have a resistor in the positive lead to the distributor, should be mallory 700. If you do not have the resistor you will burn out your coil.
Replace coil and add the resistor in the power line.
good luck,
Perry.
Old 06-29-2012, 05:00 PM
Default Update
I called and talked to Mallory today. I explained all the symptoms and my troubleshooting procedure. At the end of my long story he said something like this is hard to diagnose over the phone, but said it sounded like the coil was working correctly and something was going on with the distributor. He recommended sending in the coil and distributor for testing. I downloaded the online repair form and will remove the components for testing this weekend. I'll put them in the mail on Monday. He said the testing will take between 2 to 3 weeks and then someone will call me with the results and repair options. It looks like I'm going to have some time to catch up on my honey do's
Jeff
Old 06-29-2012, 05:07 PM
Originally Posted by HighPlainsDrifter View Post
Hi,
good luck,
Perry.
Perry
The wiring directions for the Maxfire said there should not be any ballast resistors or loom resistance wire in the red power wire going to the distributor. It also said to make sure the red wire supplies 12vdc in the start and run position. I guess the Maxfire is different than some of the others. I don't have a resistor and have confirmed the 12vdc.
Jeff
Old 07-26-2012, 11:10 AM
Default Update
Mallory called today after testing the coil and distributor. They said the coil was fine, but they found a loose condenser on the printed circuit board of the distributor. They replaced the circuit board and tested it with my coil for 1 1/2 hours at different rpm's and it worked fine. They shipped it this morning so I should get it early next week. Believe it or not they did the work for free. Pretty amazing considering they have a 90 day warranty and these parts were bought more than 2 years ago. I'm very happy with their support and look forward to hearing the Cobra fire up again.
I asked if they were seeing very many of the Maxfires come in for repair. My thought was maybe it's not a great idea to have electronic stuff inside the distributor. She said they don't see any more of them than any of the other distributors they make. I guess that's good news. She said I could exchange it for a different model for an additional $120 if I wanted to go back to the old style mechanical advance. I'm going to stay with what I have.
Jeff
