Old 06-20-2012, 03:48 PM
rpatton3's Avatar
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Default Direction of water pump rotation
I want to add power steering and use a March serpentine setup for a Ford Power Steering pump on driver's side of a LHD car.
I think I need a four (not three) bolt pulley but I need to know if this will fit.
It is in Jeg's catalogue. What Ford pump should I get I this application fits
my engine?
I am not sure about water outlet on bottom of 427 Roush 427 SR. either.
Thanks,
There were no atheists in the foxholes.
Old 06-20-2012, 03:52 PM
DAVID GAGNARD's Avatar
You can get small block Ford water pumps in either rotation.........early models turned clockwise, later models mostly with serpentine belts turned counterclockwise.....
You'll have to figure out your belt routing and see how it falls as to which pump to get.........
David
DAVID GAGNARD
Old 06-20-2012, 05:30 PM
Cobra Make, Engine: EM
I might have a pump that will work for you.
I bought my engine from Ford motorsports and the rotation of the pump was not right so I had to replace it.
The pump and backing plate are aluminum and I have new gaskets as well.
I will get the part number and send pics if you are interested.
Roger
Old 06-20-2012, 05:50 PM
rpatton3's Avatar
Thanks!
Russell
Old 06-20-2012, 07:41 PM
Cashburn's Avatar
Backdraft Racing Dealer
Clockwise and your outlet is 1969+ style on drivers side.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 06-20-2012, 08:11 PM
rpatton3's Avatar
Thanks.
Russell
Old 06-20-2012, 09:08 PM
Mando's Avatar
I have a brand new Edelbrock reverse rotation polished water pump and housing if it suits your car and if your interested.
Regards.
Mando
Old 06-21-2012, 06:23 AM
I also have a mustang 2 power steering rack if you need it
