November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-21-2012, 02:51 PM
Cobra Make, Engine: shell valley 302
Default serpentine belt
Hi All, I have a 1995 5.0 Ho that I removed topend to install old carboration
still using serpentine system for the ccw water pump. Is it possible to
use regular v-belt system (which would make pump turn cw)?.
I know I would have to buy cw pump if they even sell one. Any
suggestion is greatly received.
Old 08-21-2012, 03:41 PM
CHANMADD's Avatar
Why???
Old 08-21-2012, 03:47 PM
so much less complicated for me.
Old 08-21-2012, 04:00 PM
CHANMADD's Avatar
The Ford motor has a weak nose, and with the serpintine belt you need way less tension than a conventional V belt. Also the way its routed the tension is spread around half of the diameter of the crank pulley.
Old 08-21-2012, 04:32 PM
OK understood, I would only be spinning the generator and water pump, do you think that this is a reasonable alternative?
Old 08-21-2012, 04:38 PM
I guess my question is, would the engine still have adequate cooling flow with a cw rotation?
Old 08-21-2012, 05:00 PM
CHANMADD's Avatar
Sorry I have only three pulleys too. It is simple for sure . If you change the water pump it will work just the same.Heres a link,
http://marchperf.com/gallery_ford.html
Old 08-21-2012, 05:15 PM
lots of great pics on that page, I think Ill try the cw rotation and see what happens.
don't have much to loose as I have been trying to get the chance to drive this thing for 8
years. thanks much for the help!
Tags
serpentine belt, water pump
