08-26-2012, 12:53 AM
ESP
Cobra Make, Engine: NAF 289 Blue/White strips
Help ident. Head`s on SBF 302
Hi,
Currently I try to find out which parts my engine has got.
The heads do not have outside visible number or identification.
The intake manifold is from Ford Motorsport.
The cam is from Comp Cam part n° 31-760-8.
Maybe someone can help me identify the heads.
Rico
Rico, NAF 289
08-26-2012, 11:21 AM
Pop the valve cover off and you should find some identifying markings.
DD
Dangerous Doug
"You're kidding, right?"
08-26-2012, 12:01 PM
ESP
DD, I know, but its to early to take off the covers. No spare gaskets  . And, at the moment I like to drive the car, becauce I haw to make the AFR Test with the LM1.
After surfing the internet, I think ther are a kind of older Ford ALU Heads.
Rico
Rico, NAF 289
08-26-2012, 01:36 PM
Someone has replaced the cup plugs with threaded plugs (good idea) and machined them flat with the surface. Never seen them as OEM on SBF heads.
08-26-2012, 03:37 PM
KS
Please expand if you can!
DD
DD, I have a Ford 5.0 HO (I think, at least that's the word on the street) and would like to be able to identify year and "model" of head. I can get under the valve covers easily.
Do you have a link to a chart with the identifying marks? I recently replaced my valve-cover gaskets and did see some marks on the head inside the valve covers, but did not have any sort of chart and did not make a note of them. I will remove a valve cover again if I can find a chart to identify year of manufacture and "model", i.e. 5.0 HO, roller cam, that sort of stuff.
My heads are cast iron, not aluminum like the OP's.
Thanks for whatever you can provide in the way of information.
Cheers from another (dangerous) Doug!
YD,E./PNB
08-26-2012, 04:13 PM
OR
My heads are older, but are clearly marked "65" between the rocker arms
ERA FIA 2088
08-26-2012, 05:35 PM
Rico/Doug:
You could check here.......
Ford casting ID numbers and part identification info for Mustang Shelby parts
might help,but it is for older parts, or just take pictures of all the number/letters you can find on the head and post them here,or go to a Ford dealer parts department with them, they could look up the numbers.....
Your heads look like some late 80's to early 90's Ford aluminum heads, possibly J302 heads,which BTW are pretty good.......
Back then,Ford did have a fair amount of over the counter performance items for small blocks.....
DAVID GAGNARD
08-26-2012, 05:47 PM
As I recall the J302 heads were originally made by Alan Root and were marketed by Ford Motorsport in the late 80's. They were the first Aluminum heads for SBF but didn't have a real good intake port on them and consequently didn't receive a lot of development. Later various makes addressed the port deficiency and made great strides.
08-26-2012, 05:51 PM
08-26-2012, 06:02 PM
There is a 90 model Mustang running aorund town with a 377 stroker built back then with the J302 heads,they may or may not be "stock", I don't know, but it makes some serious power.....
Back then, that's about all one had to work with.....
DAVID GAGNARD
08-27-2012, 12:26 AM
Good advice here on where to go to identify the markings.
One thought on those machined plugs: if somebody went through the trouble/cost of fitting and machining those plugs, I'd be willing to bet there has been some porting/polishing/valve work done as well. Interesting...
DD
Dangerous Doug
08-27-2012, 04:33 AM
DD
Most likely.......
DAVID GAGNARD
08-27-2012, 06:16 AM
ESP
Thanks for all the inputs.
The car was build in 89/90. NAF Tag says 89.
Engine build in 19..? The only advice I haw about the engine is a WORK Order Tag. See foto. Engine quotet at 400 HP.
But reading your replays its possible they are Alan Root Heads. As you made me curious I will take off the covers next weekend.
Rico
Rico, NAF 289
08-30-2012, 08:49 AM
ESP
So, the cat is out the bag. I moved the cover from the passenger side Head, and on the fotos you can see the results.
I think the Heads are not bad. The engine sound`s and run`s well and it makes not problem to rev them up to 7000 rev`s.
Some coment about the stamped numbers on the Heads?
Valve diameter? Best way to check?
Rico
Rico, NAF 289
08-30-2012, 09:39 AM
Although it looks like J602,I'm sure it's sure the casting and those should be J302 heads, not bad heads at all.....
Valves are most likely 1.94 intake and 1.5 exhaust.....unless the builder put in larger valves,then they would most likely be 2.02 intake and 1.6 exhaust...
If your happy with the engine and it revs to 7000 rpms, leave everything alone and enjoy it.......
DAVID GAGNARD
