Like Tree3Likes
  • 1 Post By Hotfingrs
  • 1 Post By Rick Parker
  • 1 Post By Gaz64
Old 09-06-2012, 02:13 PM
Default Coolant in the oil???
So I thought I had a blown head gasket but when I check the compression on each cylinder all of them were about 140psi so I am guessing it is not the head gasket that is causing lots of coolant to get into the oil. Not sure what else it could be any ideas??
Old 09-06-2012, 02:26 PM
Hotfingrs's Avatar
Intake gasket
Fletch189 likes this.
Jack
XSSIVE .....
Old 09-06-2012, 02:30 PM
Rick Parker's Avatar
Ditto!
Old 09-06-2012, 03:26 PM
huh, why didn't I think of that. Sure beats having to replace the head gaskets.
Old 09-07-2012, 05:15 AM
Gaz64's Avatar
It could still be a head gasket even if you have good compression.
Cooling system pressure into oil drainback passage between head and block.
Old 09-07-2012, 06:04 AM
Could it come form the front cover as well? is there a way another way to test for a blow head gasket other than a compression test?
Old 09-07-2012, 06:31 AM
bobcowan's Avatar
Yes, it could be from the front cover. That's not very common, though.
There are a couple of tests you can do to narrow it down. Use a cooling system test kit to check for pressure changes. Autozone will loan you the kit for free.
Also, you can buy a coolant test kit that checks the coolant for by products of combustion.
Head Gasket or Combustion Leak Test Procedure (Gasoline Engines Only)
http://www.blockchek.com/instructions.htm
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 09-07-2012, 03:20 PM
Caprimaniac's Avatar
Or use pressurized air in cooling system.
Hopefully intake gasket.
Worst scenario a cracked cylindr...
Rs
