Like Tree2Likes
  • 2 Post By Hotfingrs
Old 01-23-2013, 11:55 AM
GBowman's Avatar
Cobra Make, Engine: BDR #1230/B2 445CI SBF
Default How much power???
So I'm bored and thinking about going a bit "over the top"...currently have a Ford Racing alum 351/427 which was dyno'd at 575HP (understand that dynos are all different but this is what the print out that I have from the builder says) w/TKO600 in a BDR car. I want to put a nastier set up in it that is reliable. Besides the engine itself, what would I need to change to handle additional power? Half shafts? Rear? How much HP/torque can my current set up handle?
Been considering a Paxton type set up but do not have any real experience with anything besides a straight up motor with a carb. Maybe a big block would do it for me-I've owned a few BB's but not in a car this light.
What would the dream engine/drive line be for someone who like going fast in a straight line but also wants to be able to drive it a lot on the street? Using 40,000 as a budget ceiling.
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
Old 01-23-2013, 12:05 PM
Cashburn's Avatar
Backdraft Racing Dealer
It generally does not pay to do that to an existing car, you are usually better off selling and rebuilding it right out of the box. To handle the power levels over 600HP we implement the LSD differential (mostly for the polished gear set and other enhancements done when it's built) and also the differential gets solid mounted (aluminum bushings) to keep it from moving. Other than that the cars have seen over 700HP. The power in a supercharged car comes on differently then if you were to put a Winston Cup motor in there...
For the power mixed with overall drive ability the Coyote with Supercharger is hard to argue. We are finishing one up now that will easily make 700HP, but we will likely pull it back for safety. Another one we did here:
I baby them since they are fresh...
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 01-23-2013, 12:13 PM
I'll say. Oh well, I can't argue about safety. OP -- the weakest point on Jag based rears are the stub axles. We've seen them go recently with less horsepower than you have right now. If you're seriously going to go that high with the power, I'd start from scratch.
Old 01-23-2013, 12:56 PM
Senile Club Cobra Member
BDRs are not Jag diffs, they are BMW. What is the power capacity of the halfshafts?
rick@autoventureusa.net
Old 01-23-2013, 12:58 PM
Cashburn's Avatar
They are not BMW halfshafts
VINTAGE MOTORSPORTS
Old 01-23-2013, 01:06 PM
Thor maine's Avatar
If you like the handling and driveability you have now ??? Have you thought about a nitros set up??? An extra 100 or 150 H.P can solve a lot of boredom problems!!
Old 01-23-2013, 02:27 PM
GBowman's Avatar
Talking
We have the beginnings of a plan...Now I need Jay to get me near that 700 # without breaking something
Gary Bowman
Old 01-24-2013, 04:04 AM
Gary, call me....I have a nice SBF package that would get you where you want to be.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 01-24-2013, 08:16 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Build a tank. LOL
9 inch rear with 31 splines.
Romeo 605 with dual turbos or supercharger(s) = 1000+ HP
Just a thought.
Old 01-24-2013, 04:33 PM
rpatton3's Avatar
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Wouldn't the compression be kinda high is your 427 Windsor is 575 HP?
Boost makes HP and also holes in pistons.
There were no atheists in the foxholes.
Old 01-25-2013, 12:25 AM
Thor maine's Avatar
I am a "Car Craft- HotRod " kinda guy and Nitros would be the cure for your "boredom" and a shot in the arm would probably not destroy your drivetrain.
Old 01-25-2013, 06:06 AM
Cobra Make, Engine: 427
I would bet you're experiencing more of a lack of traction than power. These are not all Wheel drive . You Have at best 1 And 1/2 tires to put the power to the pavement.
Your BDR with an aluminum block should be at around 2300 pounds. at your rated power even if your Motors torque Curve may be high probably maxing over 5500 RPMs Throwing any more power added May only make the situation worse.
Old 01-25-2013, 08:06 AM
Man, you've got bigger ones than I do.
My engine puts out 550hp and 575 lb ft. at the crank and even with sticky tires I can get sideways in third gear with just a firm push on the pedal. Don't know what I would do with another 200 horsepower except ruin more pairs of underwear than I already do.
I don't even consider flooring the throttle in any gear below fourth unless I'm going straight and have no cars or steep dropoffs on either side of me.
Jim
Old 01-31-2013, 04:34 PM
GBowman's Avatar
Thats the idea...pedal thru 1st and 2nd...ease into 3rd then hammer it at the top of 3rd, all while going straight ahead. I live in NJ...everyone wants to beat up the old guy from one light to the next
Gary Bowman
Old 02-01-2013, 03:53 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Build the suspension right, and you shouldn't have to pedal much is first. This video is on street tires.
Turn up the volume
Jack
XSSIVE .....
Old 02-01-2013, 07:38 AM
GBowman's Avatar
Hotfingers-That is one BADASS ride!!! I dont think my LSD could ever do that
What is your best ET on street tires?
Gary Bowman
Old 02-01-2013, 07:41 AM
GBowman's Avatar
Oh...and Im reasonably certain the Wife would make me get that 2nd roll bar that I refuse to install
Gary Bowman
Old 02-01-2013, 08:26 AM
Hotfingrs's Avatar
Street tires = mid to high 9's best on slicks 9.14 and this is an IRS
Jack
XSSIVE .....
Old 02-01-2013, 09:29 AM
Cobra Make, Engine: Everett-Morrison, 434 cid
You running steel halfshafts?
Old 02-01-2013, 10:06 AM
Hotfingrs's Avatar
The halfshafts are aluminum
scottj and Jerry Clayton like this.
Jack
XSSIVE .....
