Old 03-13-2013, 05:12 PM
Cobra Make, Engine: jbl
Default ford mini starter amperage draw
anybody know the amp draw of a ford mini starter for something like a sbf, there are no markings on the starter and i can't find it on the internet, and i am just looking to get an idea if i was to run a parallel type fuse in the battery cable. thanks.
Old 03-13-2013, 07:28 PM
I have the old-style OEM FE starter, but I can tell you specifically what it draws. See: 300 amp X 12 volt Circuit breaker for a pic and details, but the long and the short of it is that it draws over 900 amps peak surge. Yep, 900 amps -- and over 200 on the constant crank.
Old 03-13-2013, 07:43 PM
Dwight's Avatar
Smile
never hear of anyone fusing the battery / starter cable.
most of us install a shut off switch.
Dwight
Old 03-14-2013, 01:33 AM
i have a switch, or had a switch. it was a pos longacre with the handle wabble and was only rated for 150 amps, so another is on the way. looking through a nice new electrical book and the guy wired two 200 amp resettable breakers in parallel prior to the switch so i was thinking about something like this, and wondering how many amps the starter does pull. the breakers also had valet mode, so you could disable everything from there also.
i figured allow for at least 250 amps, that is what one of the smaller advertised tilton starters was advertised at. 935 amp surge is a pretty good jolt.
Old 03-14-2013, 11:52 AM
The inrush current when the starter motor is first engaged is everything the battery can supply. If you have a 1000 amp battery it will pull all 1000 amp.
Once at steady state, turning the engine over, if it takes 5 Hp to spin the engine, it will pull over 300 amp. On a warm day, it may be less on cold day it can be much more.
The factory does not fuse the starter, for a reason. The battery is what limits the current. Your headed down a road of trying to improve something that needs no improvement. Your just going to cause yourself a heap of trouble for no good reason.
The switch you had was not up to the task. Either eliminate it or get one that is up to the task.
Rate This Thread:
