January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree2Likes
  • 1 Post By Cashburn
  • 1 Post By 68pony
Old 06-23-2013, 06:44 PM
Cobra Make, Engine: Superformance #522
Default Ford Racing Z Cylinder Heads
Looking for feedback on Ford Racing Z heads. Upgrading from 351 to stroker....most likely 427. Are the Z heads suitable for a 427 @ 550HP? Peak HP around 5500 and peak torque around 4500 with 240-250 duration cam.
Old 06-23-2013, 07:05 PM
Port and chamber, valve sizes and flow numbers would help.
If you want 550HP they need to flow at least 300cfm at .600".
Chas.
Old 06-23-2013, 07:29 PM
Cashburn's Avatar
Backdraft Racing Dealer
All the 427 Ford Racing crate motors we have dynoed or seen actual dyno charts from have done over 550HP. So that's my way of saying yes they can get there.
vatdevil likes this.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 06-23-2013, 08:55 PM
With so many other good brands of heads out there why the ford racing Z heads,also you may have to use different headers with the Z heads, I know I had to, the exhaust ports were a different height, if I could do it all over again I would not buy anything with the ford racing name on it, the Z heads on my 427 crate engine had soft valve springs and soft valve guides and was a brand new engine, smoked like a chimney stack from the very first start up, check thread below.
cheers chris.
Ford Racing 427 burning oil
Old 06-24-2013, 04:35 AM
I would opt for something else...AFR, TFS, RHS, Dart, etc.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 06-24-2013, 05:21 AM
Brent,
Looking at AFR, the 195 competition head bench flows more than the Z head, even more than the AFR205. Looks like a good option for what I'm after, 427 that's very streetable. I need a very broad and flat power curve for autocross....2000-6500 range.
Old 06-24-2013, 05:23 AM
A smaller head would be better for autocross. AFR's are hard to beat, TFS heads are even harder to beat if you have the pistons set up for them. An AFR 195 would be a good choice. Look for good flow numbers at lower lift levels too. Remember, a smaller head with equal or better flow numbers is a plus...
Rate This Thread:
