Old 07-26-2013, 11:27 AM
Default NGK spark plug heat range
Anyone has experience with this manufacturer? What heat range should be used as a starting point for 9,5:1 compression with Ford Duraspark Ignition?
Simon
Old 07-26-2013, 12:42 PM
I would start with a 6 or 7 (6 being hotter). But u can call or email NGK for better advice.
MP
Old 07-26-2013, 03:18 PM
Yes, call their techline-very helpful
Chas.
Old 07-27-2013, 11:16 AM
Thanks, will do!
Old 08-17-2013, 08:19 PM
Rick Parker's Avatar
What reach plug do you require? Is it tapered seat or 14mm gasket style?
Old 08-17-2013, 09:50 PM
bobcowan's Avatar
As a ball park figure, for every 100hp you add to the stock engine, you should drop one heat range from the stock recommended plug.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 08-18-2013, 02:22 AM
I ended up with the BCP7ES-11 (14mm gasket style). Engine is running strong, no fouling in stop and go also. Gap is set at 0.035"
Old 08-20-2013, 08:09 PM
Excellent
