| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
04-03-2014, 07:51 PM
TX
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Help me understand stroker kits
I purchased a kit and am trying to make sure I did it right. I'm not quite ready to panic, but want to make sure its right before I take the parts to the machine shop and make them unreturnable.
The packing list from scat tells me to unpack everything and check it with what I ordered to make sure it is right. In the process of doing just that, I may have found an error, but am not sure I'm reading it right.
I ordered a stroker kit for a 351W to go to 408. I ordered a 28oz imbalance, 28oz imbalance flywheel, and 28oz imbalance damper.
When I got the kit from Scat, it has crank # 9-251-400-6200-2100W. When I go to scat's website ( click here, click on Ford, Crankshafts, Cast Series 9000, scroll down, 6th from the bottom) it lists this crank as "Neutral Bal Int".
Can I use this neutral balance interanl crank with my 28oz flywheel and 28oz damper?
If I click on Rotating Assemblies, Small Block 351, then scroll down to the kit I ordered (part 1-94306 - Inclcrprb - does this mean includes crank, rods, pistons, rings, bearings?), it doesn't list this kit as internal or external, but the column header for Compl (complete kit?) shows 1-94306BE. I think that means balanced externally.
So, what is the difference between a bare crank that is internal balanced, and a kit that uses that crank that has an external balance if used in the complete kit? What is in the complete kit that is not in the kit I received?
Tom
04-03-2014, 10:04 PM
Ca
What Length rod are you using? I believe the additional weight of the longer rod (if being used) allows weight to be taken out of the Harmonic Balancer or Flywheel in an effort to go towards Neutral Balance.
Rick
04-04-2014, 05:31 AM
TX
They are 6.2 inch rods.
04-04-2014, 05:41 AM
AL
can you return the 28oz imbalance flywheel, and 28oz imbalance damper.
and buy zero balance flywheel and damper?
Dwight
04-04-2014, 05:59 AM
ny
Cobra Make, Engine: SPF
If the parts are correct for the block, won't the shop balance rotating assembly?
04-04-2014, 07:05 AM
TX
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
Your best bet is to call Scat and talk it over with them. The internals and externals have to match.
Steve
Texas Cobra Club-Seguin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
04-04-2014, 07:21 AM
CA
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Seagull is correct. Go to the source. And on most flywheels and dampners the weights can be removed for neutral balance
04-04-2014, 01:12 PM
mo
Cobra Make, Engine: B&B 351C
I asked the same question to my engine builder, i built a 351 cleveland to a 408, used scat rotating assembly, i was told to buy a 28 oz imbalanced flywheel, when i asked the builder as to why he said he always has to balance engines even if they say it's balanced, and also it is easier to balance the rotating assembly with the imbalanced flywheel as opposed to adding malory if needed, i quess he knows what he is doing as my motor in my mustang made 830 hp and the one in my cobra made 547hp. chances are you might have to balance your damper also. I hope i explained it right or i am going to look pretty dumb!
