2Likes
12-08-2014, 08:22 PM
Proud Club Cobra Member
MD
Cobra Make, Engine: ERA 2121
Show me your Valve Covers
Having a difficult time finding plain steel valve covers to work with roller rockers and Weber IDFs.
If it's not the rockers hitting the baffles... it's the accelerator pump shaft/rod hitting the valve cover...
What's everyone using with this setup?
12-08-2014, 09:00 PM
AL
maybe this will help. Erik lives in Huntsville, Ala.
Are you a member of the Chattanooga Cobra Club?
Dwight
"The Black Mamba" 289 FIA Build - FFCars.com : Factory Five Racing Discussion Forum
12-08-2014, 09:20 PM
NV
valve covers
12-08-2014, 09:33 PM
NV
I'm using the breather in the timing chain housing. There are many options as far as ventilating your engine you just have to be creative i.e. venting through the intake into the lifter gallery. I'm sure most valve cover will clear 1.6 ratio rockers but you might have interference with the larger ratio rockers. What type are you using?
12-08-2014, 10:38 PM
.........using stainless steel roller rockers:
12-08-2014, 11:50 PM
Cobra Make, Engine: Contemporary Classic 289 FIA
Show Me Your Valve Covers
Does anyone know where to purchase the valve cover decals?
12-09-2014, 04:46 AM
12-09-2014, 07:23 AM
Which ones?.............
12-09-2014, 08:39 AM
Show off!
12-09-2014, 11:52 AM
pa
Cobra Make, Engine: era 289 FIA #2112
I am using steel covers with an aluminum spacer to clear the roller rockers
live for the moment or it may pass you by
12-09-2014, 12:42 PM
12-09-2014, 02:55 PM
Full Blown Member
1985 CCX,
Nice garage art!
And I agree with ACademic
rodneym
12-09-2014, 06:00 PM
Thanks for the purchase recommendations. I ordered the Cobra valve cover decals for my 289 FIA today. I see some of you adhere the whole decal and others separate the COBRA part of it from the remainder of the decal which some 289 Comp cars did in there day.
12-10-2014, 07:27 PM
My wife agrees
12-17-2014, 10:06 AM
MD
Dwight:
Yes, Chattanooga Cobra Club. Mark has done a fantastic job in “recruiting” about 100 members!
Thanks for the link. Beautiful FIA! Unfortunately, those spacers won’t work with my combo.
Legenmetals & CompClassics:
The IDAs & manifold are set up differently and offer more real estate between the carbs & covers.
I’m using Scorpion 1.6 rockers.
1985CCX:
Wish I lived next door. Quite the selection. One of ‘em has to fit!
Gaz64:
Thanks for the link & the advice. Spacers under the carbs would solve the accelerator rod hitting the valve covers but create a hood clearance issue. I’m thinking of adding ¾” reliefs where the rods hit the cover so tall stamped steel may be the best option since I’ll need to weld. Weber setup was purchased used a while back. I must have some odd ball manifold…
Reason: attempted pic upload
12-17-2014, 12:34 PM
Thought I would show the valve covers I am putting on a Shelby FIA car that I have on the way. Jim
12-17-2014, 01:35 PM
A switch to Comp Cams stainless steel roller rockers will fix your problem, maybe not I thought the issue was the rockers hitting the covers. Looks like you will be working in uncharted territory.
12-17-2014, 03:24 PM
looks good.
Reason: delete
12-24-2014, 08:31 AM
Cobra Make, Engine: Superformance, 427SO
Don't know if this will help you, but you might want to check out Coleman Racing's valve covers, part # 11569.
Home Page
Ted
12-24-2014, 11:50 AM
Very nice!
