Like Tree2Likes
Old 04-18-2015, 11:18 AM
Chaplin's Avatar
Gotcha. Tnx.
Replica is not a dirty word.
Old 04-18-2015, 11:22 AM
If you're looking for a curve like this, you'll need some cubes....
Old 04-18-2015, 02:21 PM
Chaplin's Avatar
Smile
Yes, that would work.
Old 04-18-2015, 08:13 PM
cycleguy55's Avatar
As the saying goes: "There's no replacement for displacement."
Brian
Old 04-19-2015, 04:47 AM
Karl Bebout's Avatar
B, what are you thoughts about Dart Pro 1 aluminum heads? Haven't seen any mention of them.
Karlos
Old 04-19-2015, 06:05 AM
I've never used a set so anything I said would be just an educated guess....
Old 04-19-2015, 05:04 PM
Brent, do you perform any of the machining or porting of the heads in-house?
Old 04-20-2015, 02:53 AM
No sir, I use 2-3 guys who do nothing but carve on heads all day long.
Old 04-20-2015, 07:33 AM
Default Internal vs. External Balancing
Brent -- I don’t think I missed it in your description of the two engines, I saw it was noted they were Scat cast cranks, but were the rotating assemblies internally or externally balanced? Is internal balancing something you highly recommend if going with a new stroker build anyway, or is it not really worth the expense unless for a build that is going to see some demanding, high RPM operation?
Along the lines of expense, approximately how much does it add to the cost of a build? I have always read that it adds to the cost, but I don’t think I have ever seen a dollar figure stated. I think I saw on the Eagle website where all of their 4340 forged cranks are internally balanced, and obviously more expensive, but wondered if when going with a cast crank, if internal balancing is overkill. Any opinions and dollar figures welcomed.
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
Old 04-20-2015, 07:36 AM
Both were 28oz engines.
On a cast crank, it's hard to justify the price to internally balance, but on engines where we are making big horsepower and turning higher rpms, I'll use a steel crank anyway.
Here, it's about $150 to externally balance and then the price to internally balance is the price of the heavy metal and installation. Most internal balance situations are around $350-375.
Old 04-20-2015, 07:40 AM
Wow that was quick! Thanks Brent. Great info!
Old 04-20-2015, 10:39 AM
Default Boss 302
I have a 1970 Boss 302 with the original block, crank, intake manifold and
Cleveland heads. The Crane solid roller cam, Holley 650 double pumper
carb and 10.5/1 pistons are new. MPG port plates are installed for both the
intake and exhaust to smooth out the midrange and the car runs well on the
street with no stumbling. What are the pros and cons with a setup like this
and would better flowing modern heads be a better choice for this engine as
installed in an ERA FIA Cobra?
