Like Tree1Likes
Old 12-11-2015, 08:00 AM
Go for it and disclose displacement. In general and to be fair, those that offered up "revised guesses" after looking at other inputs shouldn't count. We all could have done that, the first guess should be it.
Old 12-11-2015, 09:41 AM
legenmetals's Avatar
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
agreed
Old 12-11-2015, 09:47 AM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
289 cu.in.
495 hp
Dave
Old 12-11-2015, 01:33 PM
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
289 cu. in.
400 hp
Old 12-12-2015, 04:13 AM
Well the answer to the first portion of the game is.......
(Drum roll please....)
293 cubic inches (I'll accept 292)...
It's a C5 289 block, .030" over. Crankshaft is a new steel crank at 2.870" stroke. (4.030/2)^2 * 8 * PI * 2.870 = 292.8
Tom Cimino, the math should be:
Deck height - rod length - piston compression height - 1/2 stroke.
8.195 - 5.700 - (2.870 * .5) = 1.060" compression height.
Normally, at this compression height, the oil rings do intercept the wrist pin (not a problem), but since the ring pack is so thin, it gets it up out of the way.
So, there are a couple of guys who were dead on with the displacement:
G Edmonds
Jac Mac
DWRAT
jhirasak
Lots of guys guessed 289, which is close, but going .030" over adds a few cubes.
Congratulations guys, it's literally the final four....LOL
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 01-22-2016, 10:44 AM
DWRAT's Avatar
G Edmonds
Jac Mac
DWRAT
jhirasak
So when will the dyno #s be known?
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 01-22-2016, 10:47 AM
Running behind....
Head porter just finished with heads and intake and I still have to send the intake to Jim Inglese to have the carbs fitted.
It will be a bit.
Old 12-12-2015, 09:17 AM
Missed it by a mile. The "aftermarket caps" was the clue that I missed (used block, bore will need cleaned up). I was thinking new block.
Good job final four.
Old 12-12-2015, 04:39 PM
DWRAT's Avatar
I'm in the final four.
That was the easy part, now for the hp #s.
FFR MK1---Sold
No more Furds.
Old 12-12-2015, 11:08 PM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Yes, on that note it would be handy to know all the rules/specifications the engine build has to comply with...
Jac Mac
Old 12-13-2015, 08:59 AM
Quite a few years back, I stumbled onto a Ford dyno test of a race 289 back in the 60's. I don't remember much of any of the details, but it seems they were getting about 450 hp.
Now we have learned a lot since then, but the dyno math has changed (1960's showed more power than today). I don't know if these two cancel each other out or not. I think I will error on the side that knowledge has grown more than the difference on Hp calculations.
So I will take a wild guess at 475 hp at 7500 rpm and 380 torque at 5000.
Old 12-14-2015, 04:03 AM
Rules state that is has to be factory bore/stroke, with up to .060" overbore allowed.
Factory block has to be used, factory heads have to be used.
Valve head diameters are restricted to 1.875" intake and 1.625" exhaust.
Compression ratio is limited at 12:1.
Factory style rockers have to be used. No roller stuff.
Solid flat tappet camshaft, .525" lift at valve.
Weber intake with 48 IDA's.
No electronic ignition.
Old 12-14-2015, 09:00 AM
Cobra Make, Engine: ERA FIA #2064 BOSS 302 CSX2047 sold
I messed up part one but for part two I would guess 393hp.
Old 04-23-2016, 12:58 PM
Hats off to Dwrat
Looks like it would have made just under 450 Hp somewhere near 7500 Rpm. That's in the ballpark of back in the day. Very interesting.
Old 12-14-2015, 05:32 PM
Cobra Make, Engine: Cutting Edge, Boss 429
292c.i. / 435h.p.
Old 01-22-2016, 10:56 AM
Any pictures of the porting?
Old 01-22-2016, 10:58 AM
Nope, that's part of the hush-hush stuff.
Old 03-20-2016, 07:32 AM
DWRAT's Avatar
Any update on the HP #s
FFR MK1---Sold
No more Furds.
Old 03-20-2016, 08:09 AM
Hope to have numbers in the next few weeks. Changing some things on the heads....
Old 03-31-2016, 04:07 AM
Had to do a little experimenting....juggling between valves, spring pressures, etc.
Ended up with Ferrea titanium valves all the way around. Intake valve is a whopping 68g. Exhaust valve weighs 63g. This is one of the lightest valvetrain setups that I've seen...titanium valves, beehive springs with titainium retainers, etc.
Valve job will be done tomorrow, heads should be assembled tomorrow as well if no problems pop up. Then I can measure for pushrods and get things going.
Due to the dyno throttle servo and the way the Inglese intake is setup, I won't be able to dyno it with the Webers. I do, however, have a prepped Victor Jr. intake that I'll dyno with.
Rate This Thread:
