Like Tree1Likes
  #61 (permalink)
Old 12-11-2015, 06:48 AM
Ok, would it be unfair to make this a 2-tier contest? Obviously, everyone has had access to the same information.
Since the displacement is already known, would anyone have any objections to calling an end to the first portion of the contest tonight at midnight? With post views approaching 1700, I'd say almost everyone who is going to participate has already participated.
With the first portion of the contest ended, then the guys who are still left can have another guess at the horsepower and I may throw in a few more build specs.
  #62 (permalink)
Old 12-11-2015, 08:00 AM
Go for it and disclose displacement. In general and to be fair, those that offered up "revised guesses" after looking at other inputs shouldn't count. We all could have done that, the first guess should be it.
  #63 (permalink)
Old 12-11-2015, 09:39 AM
Bernica's Avatar
Senior CC Premier Member
Sounds fair to me.
  #64 (permalink)
Old 12-11-2015, 09:41 AM
legenmetals's Avatar
agreed
  #65 (permalink)
Old 12-11-2015, 09:47 AM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
289 cu.in.
495 hp
Dave
  #66 (permalink)
Old 12-11-2015, 01:33 PM
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
289 cu. in.
400 hp
  #67 (permalink)
Old 12-12-2015, 04:13 AM
Well the answer to the first portion of the game is.......
(Drum roll please....)
293 cubic inches (I'll accept 292)...
It's a C5 289 block, .030" over. Crankshaft is a new steel crank at 2.870" stroke. (4.030/2)^2 * 8 * PI * 2.870 = 292.8
Tom Cimino, the math should be:
Deck height - rod length - piston compression height - 1/2 stroke.
8.195 - 5.700 - (2.870 * .5) = 1.060" compression height.
Normally, at this compression height, the oil rings do intercept the wrist pin (not a problem), but since the ring pack is so thin, it gets it up out of the way.
So, there are a couple of guys who were dead on with the displacement:
G Edmonds
Jac Mac
DWRAT
jhirasak
Lots of guys guessed 289, which is close, but going .030" over adds a few cubes.
Congratulations guys, it's literally the final four....LOL
  #68 (permalink)
Old 12-12-2015, 09:17 AM
Missed it by a mile. The "aftermarket caps" was the clue that I missed (used block, bore will need cleaned up). I was thinking new block.
Good job final four.
  #69 (permalink)
Old 12-12-2015, 04:39 PM
DWRAT's Avatar
I'm in the final four.
That was the easy part, now for the hp #s.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
  #70 (permalink)
Old 12-12-2015, 11:08 PM
Jac Mac's Avatar
Yes, on that note it would be handy to know all the rules/specifications the engine build has to comply with...
Jac Mac
  #71 (permalink)
Old 12-13-2015, 08:59 AM
Quite a few years back, I stumbled onto a Ford dyno test of a race 289 back in the 60's. I don't remember much of any of the details, but it seems they were getting about 450 hp.
Now we have learned a lot since then, but the dyno math has changed (1960's showed more power than today). I don't know if these two cancel each other out or not. I think I will error on the side that knowledge has grown more than the difference on Hp calculations.
So I will take a wild guess at 475 hp at 7500 rpm and 380 torque at 5000.
  #72 (permalink)
Old 12-14-2015, 04:03 AM
Rules state that is has to be factory bore/stroke, with up to .060" overbore allowed.
Factory block has to be used, factory heads have to be used.
Valve head diameters are restricted to 1.875" intake and 1.625" exhaust.
Compression ratio is limited at 12:1.
Factory style rockers have to be used. No roller stuff.
Solid flat tappet camshaft, .525" lift at valve.
Weber intake with 48 IDA's.
No electronic ignition.
  #73 (permalink)
Old 12-14-2015, 09:00 AM
I messed up part one but for part two I would guess 393hp.
  #74 (permalink)
Old 12-14-2015, 05:32 PM
Cobra Make, Engine: Cutting Edge, Boss 429
292c.i. / 435h.p.
  #75 (permalink)
Old 01-22-2016, 10:44 AM
DWRAT's Avatar
G Edmonds
Jac Mac
DWRAT
jhirasak
So when will the dyno #s be known?
FFR MK1---Sold
No more Furds.
  #76 (permalink)
Old 01-22-2016, 10:47 AM
Running behind....
Head porter just finished with heads and intake and I still have to send the intake to Jim Inglese to have the carbs fitted.
It will be a bit.
  #77 (permalink)
Old 01-22-2016, 10:56 AM
Any pictures of the porting?
  #78 (permalink)
Old 01-22-2016, 10:58 AM
Nope, that's part of the hush-hush stuff.
  #79 (permalink)
Old 03-20-2016, 07:32 AM
DWRAT's Avatar
Any update on the HP #s
FFR MK1---Sold
No more Furds.
  #80 (permalink)
Old 03-20-2016, 08:09 AM
Hope to have numbers in the next few weeks. Changing some things on the heads....
