Like Tree6Likes
Old 01-25-2017, 10:42 PM
Texasdoc's Avatar
Default Thoughts on oil pressure vs flow?
I've always wondered what weight of oil would be best in my car. I built my own motor so I can't "just ask the builder what he recommends"...
I've heard some say "Put 10W-30 in everything" and just drive it. That's what I have been using. With my HV pump I get 75 PSI cold idle, 40 PSI hot idle, up to 70 PSI cruise.
I recently came across an article on BITOG that made the remark that no oil at ambient temperatures (anything less that 120 degrees Fahrenheit) is thin enough to flow well - so use the lightest oil made 0W. They also agreed with the 10psi per 1000 rpm rule. So their summary was to use 0W-XX - the XX being whatever weight oil fulfilled the 10per1000 rule with a minimum PSI of 15 at idle when hot. So if I get 70 PSI at 3000 RPM cruise with 0W-40, I should decrease the viscosity to 0W-30 or 0W-20 to get the pressure down. Lower pressure = higher flow. It is the "flow" that provides protection, not the pressure.
Thoughts on this logic?
Old 01-26-2017, 04:11 AM
It's hydrodynamic pressure that provides protection.
Desired oil viscosity is based on a couple things....two of which are:
1. Bearing clearances
2. Your environment
Most of my street engines run about 30 psi at idle and 70 psi going down the road. I use 10W-30.
I've been following your threads and you are way overthinking the oil to the top end deal. The internet can be helpful in a lot of cases. It can also be totally out in outer space in a lot of cases. There are a lot of engine "experts" out there who 1. Have never laid hands on an engine 2. Don't have a stinkin clue about what they're talking about.
IMO, you just got a set of junk heads.
Old 01-26-2017, 04:22 AM
1795's Avatar
I am interested in hearing what the engine builders have to say on this topic. There was a discussion recently among several vintage race car drivers about flow vs. oil pressure after somebody (not me) burnt their main bearings. Part of the discussion included a recommendation to go with the oil filter that offered the least amount of resistance to flow, as race engines are rebuilt more often than engines that primarily are used on the road and it is more damaging to them to reduce flow than to let some small particles through.
I would not necessarily equate high pressure with high flow volume. While there may be some overlap, I can easily see a situation where due to tight tolerances oil pressure may be high and flow low secondary to restrictions. At the same time very loose tolerances may result in high flow with low pressure.
My guess would be that many factors come into play.
Old 01-26-2017, 04:26 AM
There are too many variables to make blanket statements and sometimes it's engine specific....i.e. 289/302 vs 351W vs 351C vs FE....
Texasdoc's post stems from some issues he's been having with some AFR cylinder heads.
However, some of the things he quoted, I don't necessarily agree with.
Old 01-26-2017, 06:51 AM
This is the perfect opportunity for me to ask about my problem. I have good pressure at idle and cruising at Highway speeds, but at higher speeds and higher rpm i.e. 4500 over 100 mph the oil pressure drops. I'm using straight 30, but for this problem, I don't think that has anything to do with it. Any input would be appreciated.
Old 01-26-2017, 06:55 AM
If you're losing oil pressure with rpm, it's most likely that you're running out of oil in the pan.
Either you just don't have enough oil in the pan, or your pickup clearance is such that it's either being uncovered or too close to the pan to flow enough oil.
Could be some other causes too....a galley plug missing somewhere which causes an internal bleed, too much oil going to the top end, etc.
It's not uncommon to lose a few psi at the top end, but if you're just getting into the gas above cruise rpm and you're losing pressure, I would lean towards my previous thoughts.
Old 01-29-2017, 04:12 AM
DanEC's Avatar
There is another possibility for losing pressure at higher engine speed and that's an over-filled sump and the crankshaft frothing the oil (aeration). I experienced this in a Pontiac I once put too much oil in by accident and it was fine until I settled in on the highway and then it would start to lose pressure and the pressure would fluctuate.
ERA 782 Running
Old 01-29-2017, 07:31 AM
Back in the 1970's all the gear heads I knew were using windage trays to keep the crankshaft from whipping up air in the oil, and it was claimed a small block Chevy would gain 25 hp at high rpm, by adding one. It takes Hp to spin air.
I have read on this site NOT to put a windage tray on an FE that has the solid lifter block, because the lifters only get oil from splash. Personally I don't understand that, because the splash should be oil coming out the sides of the main and rod bearings, not splashed up from the pan. So I would think the lifters would still get splashed. But then again, I do not know everything. I have learned that when people observe something, there is usually something to it, even if it is unrelated.
I also have noticed that a lot of FE owners are the ones saying they are using X-50W oil. There are some SB Windsor guys saying they use an X-50 W oil, too, but I also here 10-30W and 10-40W a lot more. I don't recall any FE guys saying they are running 10-30W oil. Now this is a come to think of it moment. I have NOT scientifically studied and accurately counted this.
Old 01-26-2017, 07:10 AM
Thanks Bill,
I have a Milodon Oil pan and I didn't build the engine. Dipstick shows full, but could it be improperly marked? 351w Just a thought. And no,doesn't drop right after cruising speed,after. 100 and drops below 40!
Old 01-26-2017, 07:38 AM
I thought it might be a quick easy fix buy adding a couple of quarts of oil, or maybe it's a blessing in disguise.I have no buisness driving that car over 100 mph.
Old 01-26-2017, 08:11 AM
Matt,
Sounds like you are starting to lose volume in the pan or you're uncovering the pickup on high acceleration/speed.
Without knowing or assuming anything else about how the engine is assembled, your idea about trying an extra quart of oil would be something worth trying.
Also, if you're pulling your oil pressure from the rear of the block, it's not uncommon to see oil pressures like that, since it's getting "residual" pressure after all the bearings/lifters/etc. have been fed.
Old 01-27-2017, 05:00 AM
Dwight's Avatar
Smile
I'm not an engine builder
so when I build an engine I get my buddy Eddie who is an engine builder to help me. I watch him and hand him tools and do the dirty work and clean up after he leaves.
I had an engine that would run out of oil in the top of third gear (6000 rpms) 100 mph. Oil pressure gauge would go to zero. Problem was dip stick was marked wrong and the pick up was 5/8" off the bottom of the pan.
Now I clay check all pick up / oil pan clearance.
And through the years I have found several Cobra dip sticks marked incorrect. We assume the factory got it right when they made the dip stick. But they don't know what block, timing chain cover or oil pan we are going to use.
One time I was helping with a 440 and was doing some research for a oil pan. Some would list the pan as a 5 qt and others 4 qt. After a couple of hours I found the pans were the same but some would add the qt for the oil filter. I guess they though it would sell better if it sounded like it held more oil.
So now I find out how much oil a pan holds and add that amount of oil then crank the motor, let it run for a couple of minutes and shut it down. Wait 15 minutes and check the dip stick. Most of the time I have to remark or cut the dip stick. I know it very anal for a street motor but that just a flaw in me.
Dwight
Old 01-27-2017, 06:20 AM
Thanks Dwight
Old 01-27-2017, 04:42 PM
First, now days you here a lot of talk about needing to get flow to the top of the engine quickly. This talk is all about overhead cam engines. Some of the engines are aluminum heads and there is no bearing. The head just has a half round cut into it and the caps bolt to it. The only thing between the cam and the aluminum head is oil. If you do not get oil flowing to the cam quickly on a cold start, its a train wreck.
Push-rod engines do not apply to all of that talk.
Bottom line, as far as springs and valve guides go, oil flow nor oil pressure is critical in this area. In fact they use to put umbrella type valve stem seals on the valve stem to prevent too much oil from getting on the valve stem and dragging past the old cup type seals. You don't need a lot of oil going to the guides. If fact too much will cause it to burn the excess oil. The springs don't do much rubbing against anything, unless the rpms are so high that they are gyrating all over the place. Well the seat and cap see movement. Again if oil pools up, there is plenty. You just need flow to carry away some heat.
If you are getting oil out of every push rod, odds are you have plenty of oil flow.
I tend to be on the side of thinner oil in most engines. A small block does not need thick oil unless the bearing clearances are looser than I would choose to have. I run 10W 30W oil in my 5.0 / 347 stroker.
Pete Munroe likes this.
Old 01-27-2017, 09:04 PM
eschaider's Avatar
If lower pressure provided more flow then you could reduce your pressure to zero psi and get maximum flow. I have noticed that whenever my oil pressure is at zero the flow is also at zero. I suspect your experiences might be similar.
Dr. Dmitri Kopeliovich is the Director of Research at King Bearings and has been with them in that capacity since 2000. He has published 500 or so papers on Materials Engineering and Materials Engineering related subjects. He is responsible for a significant portion of the original research in the design, development and production of King bearings for both racing and non racing applications.
The following figure is from one of his papers Engine Bearings and How They Work (<= clickable).
Figure 2 above, graphically depicts how the oil is literally pumped into the space between the crank journal and the bearing insert by the rotating journal. Some of Dr. K's words, on the phenomena, which you can read if you choose to download the paper;
"Fig.2 demonstrates a hydrodynamic journal bearing and a journal rotating in a clockwise direction. Journal rotation causes pumping of the lubricant (oil) flowing around the bearing in the rotation direction. If there is no force applied to the journal its position will remain concentric to the bearing position. However a loaded journal displaces from the concentric position and forms a converging gap between the bearing and journal surfaces. The pumping action of the journal forces the oil to squeeze through the wedge shaped gap generating a pressure."
There are a wealth of additional bearing, lubrication and performance related white papers the good Doctor has published that are downloadable from the King Bearing website. I think you will find a very well organized and presented technical emporium of information specific to bearings, lubrication and race / performance engine applications that is factual.
Ford went to progressively heavier oils for their higher powered engines. The low viscosity oils they recommended for their daily driver types of vehicles had to do with CAFE (Corporate Average Fuel Economy) standards the Detroit Car Makers were required to meet.
Ford likes a 5W-50 weight oil for the new GT350 engine. Most Windsors and FE's are assembled with looser clearances which would encourage me to run something more like a 15W-40 or 50 oil if it were my engine.
Here is a pic of Ford's oil change kit for the GT350. Note the oil weight on the bottle;
The little pipsqueak engine I run uses 15W-50 Mobil 1 synthetic. My engine idles at about 900 rpm with 65psi oil pressure after it warms up. When it is cold, at first start, it idles a little north of 110 psi. When I am driving in traffic at 1800 rpm it has a little over 85 psi of oil pressure.
These slightly elevated oil pressures will consume an incrementally small but real portion of your engine's power to maintain. It absolutely guarantees a more than adequate oil delivery to all bearing surfaces in the engine as long as there is oil in the pan and my oil pump is spinning. I have never wanted for that incremental horsepower.
BTW in the FWIW category the relationship between pressure and flow for fluids is a second order relationship where the pressure increase is equal to the square of the volume increase. If you wish to double the volume flow of a fluid thorugh a given orifice then you will need to increase the pressure by a factor of 4. The bearing clearances we run in our engines represents the orifice referred to above.
You should do things for your engine that you think are best for you (and your engine).
Ed
p.s. If you choose to run high volume, high pressure oil pumps you also need a properly baffled, high volume oil pan. If you do not use one, you will pump your pan dry and smoke your engine's bearings which is one of the issues Brent was cautioning you about. Take a look at Fords oil change kit for the GT350 one more time. There are ten quarts of oil ...
olddog and 1795 like this.
Old 01-28-2017, 12:13 AM
xb-60's Avatar
Texasdoc, I agree, yes I think you’re over-thinking it. Even ‘highly-tuned’ engines can get by with less than ideal oiling conditions.
A short story….a few years ago (mid-eighties) Wheels magazine in Australia ran a bog-standard Alfa 2 litre twin cam sedan from Sydney (east coast) to Perth (west coast)….around 4000km / 2500 miles in around 29 hours, start to stop. At Port Augusta (roughly half-way) the Alfa mechanic from Adelaide met them for a quick check-over and they reported zero oil pressure at idle, and around 15psi on the gauge at their 170km/h / 110 mph / 5000rpm cruising speed. The mechanic said “he’s OK” and they continued their blast across to Perth at 15psi on the gauge and with no problems. The cause of the low oil pressure was one of the aluminium slugs that blank off the cross-drillings in the crank having come out. I know this because A. my Alfa has had the same symptoms twice and B. I knew the Alfa mechanic.
Providing your oil is thin enough at cold start-up, you’re OK (almost all the wear occurs at start-up). I could also add that my Alfa is 41years old now (I've had him for 36 years) and has clocked up over 250000 kilometres, and has always run on 20W-50 oil.
Glen
Old 01-28-2017, 10:06 AM
First Ed's post is one of the best posts to this site.
I wanted to clarify and expand a bit further on this paragraph. As a process control engineer (more on that later), I have used orifice plate flow transmitters. For accuracy you have a pipe with a plate clamped between two flanges. The whole in the plate is a smaller diameter than the pipe. The pipe must be straight (no elbows) for a length 10 pipe diameters upstream, and 5 pipe diameters down stream of the orifice plate. Now you measure the delta pressure across the orifice plate. (delta meaning the inlet pressure minus the exit pressure. You take the square root of the delta pressure and that is proportional to the flow.
Flow = K * (delta Pressure)^0.5
where K = a constant
K has to take into count the pipe diameter, the orifice diameter, and the viscosity of the fluid.
If you are pumping fluids like water the viscosity changes very little over its temperature range. The orifice plate flow transmitter is as easy as falling off of a log. It works perfectly.
If you are pumping a polymer like Polystyrene, the viscosity changes with temperature exponentially. That could be compensated for, but it gets worse. Polymers' viscosity also thins (lower viscosity), when it is put into a sheer plane. As polymer flows through a pipe the velocity of the molecules at the wall approach zero. Each layer of molecules further from the wall is traveling faster than the previous layer (closer to the wall), and the flow is greatest at the center of the pipe. This causes a shearing action between each layer of molecules. The velocity change between the layers is not all the same, therefore the viscosity change due to shear thinning is different at every layer and therefore the viscosity of the polymer is not constant across the pipe. The point to this paragraph is to explain that an orifice plate flow transmitter will not work, with a polymer flowing through a pipe. Although with a large finite element computer algorithm and a lot variables not mentioned, we can estimate pressures for design purposes, but there are so many variables that the errors in each measurement adds up to me using the words "estimate the pressure."
Ok Rick so why did you waste my time telling me about polymers when we are talking about oil? Well because the way they get oil to behave like a straight 5 wt oil at a low temp and also behave like a 50 wt oil at a high temp is that they attach molecules into chains that intertwine like a plate of sphegetty. "Attaching molecules into chains that intertwine like a plate of sphegetty" is the definition of how a polymer is made. Multi-viscosity oil is partially polymerized oil. So, it does not behave like water at all. It behaves similar to a polymer, but not nearly as extreme.
The further the spread of the viscosity numbers, on a can of oil, the more they had to polymerize the oil to accomplish that spread. A can of 5-20W oil is not as polymerized as 5-50W oil. They need longer chains of molecules linked together in the 5-50W oil, to get the 50W behavior at high temperature, because it is a 5W base oil.
So what does all this mean? Well it explains why oil pressure readings are often talked about, and there are as many opinions as there are people talking about it. You are looking at a reading that does not precisely tell you a damn thing (other than the pressure at one spot). Because there are so many other variables that you do not know, you could not possibly tell me how much oil is flowing based on that one pressure measurement.
So why does one person run 5-30W oil in his engine and another person run 5-50W in essentially the same engine and neither one of them has ever had a failure? Both emphatically states they are running the best oil. They cannot both be right. Right? Well maybe.
Because of the sheer thinning property of polymers, the oil kind of self adjusts or automatically compensates to some degree. If you put a high viscosity oil into your engine, the oil will flow slower, therefore it will stay in the bearing longer. The longer it says in the bearing, the longer is will get shear thinned, and the more heat that will put into the oil. The thinner the oil gets, the faster it will flow. Hence it somewhat finds it own temp, flow, and viscosity. So at 8000 rpm the behavior of a 5-30W oil in a bearing may not be all that different than a 5-50W oil. The temperature of the 5-30W will be less than the temperature of 5-50W oil when it exits the bearing. The shear thinning has a greater affect in the 5-50W because it is more polymerized. The viscosity of the two oils while in the bearing is much more close than you would think, given what they act like when you pour them out of a bottle.
One last point to make. Don't think, based on what I said, that you cannot put too thick of an oil into an engine, because it will just get heated and thinned more and self adjust to the right thickness in the bearing. I did not say that. The oil passages (pipes if you will) that the oil is pumped through to get to the bearings, has little shear thinning and heat affects on the oil. A high viscosity oil will only flow through the block to the bearing so fast. It is possible for a high viscosity oil to stay in the bearing so long, that the viscosity of the oil, while in the bearing, is much lower than what it would be, if a lower viscosity oil was used. Let me state that again. It is possible for a high viscosity oil to actually be thinner, and therefore less protection, while in the bearing, than a lower viscosity oil.
So from this there is a fairly large range of oils you can put into an engine, without issues. The higher viscosity oils require more hp to pump (think the shaft driving the pump getting twisted off), and they will run hotter. The oil only has to keep the metal parts from touching, beyond that you are wasting power and energy. It's a lot cheaper to waste some energy to be on the safe side than destroy an engine. However if you twist off your shaft to the oil pump and are not looking at the pressure gauge you can equally destroy an engine.
So for push-rod engines, I personally wouldn't go less than 5-30W oil nor more than 20-50W oil. I would take into count the typical oil pressure range for the engine in question and if that engine has issues with twisting off oil pump shafts or bearing failures. Generally speaking I stay away from heavy oils unless the engine runs low pressure or it is going to be pushed to the limits of holding together, such as racing. The heavier the oil the more care needed in letting the engine come up to operating temp. That said we are not talking an exact science and there is room for error and many opinions. In this range, it likely doesn't matter a whole bunch.
Not everything I have stated is 100% technically correct. I tried to put this into terms that most gear heads would grasp, so I left the crap that would put you to sleep out. I may have failed at that. I am by no means an expert on this subject, but I have some experience that applies. I just wanted to share in an attempt to reduce some of the misconceptions I read from time to time.
Disclosure: I worked for one of the largest Chemical Companies for 38 years. I started as a operator and worked 7 years as a control room operator. I went to college part time to get an electrical engineer degree. I was promoted into a job that was essentially an engineer position. I did not complete getting the EE degree. I have written process control programs that run a variety of easy to complex processes. Among many things, I worked on improving polymer pump designs, which uses the polymer that is being pumped as the lubricant that flows through the bearings. The last 8 years I have been full time in a process control engineer position. The company, I worked for, sold the plant that I work at to a new company, and I continue to work in that role, for the new company.
eschaider, RET_COP and 1795 like this.
Old 01-28-2017, 12:20 PM
eschaider's Avatar
Very impressive tour de force on polymer fluid flow and properties Olddog (apologies I forgot your first name). You nicely fleshed out the stuff (in English) I couldn't.
The whole lubrication subject for our type of engines, sadly is sometimes permeated with urban legend and internet science. Your explanation adds substantially to the real knowledge base out here. Thanks for weighing in!
Ed
Old 01-28-2017, 02:21 PM
1795's Avatar
Amazing discussion and expertise! Luckily I have enough basic scientific knowledge to follow the discussion. Thanks to Olddog and Ed!
Old 01-29-2017, 02:27 AM
RET_COP's Avatar
All of the oil viscosity discussion had been about flow and bearings. Would having hydraulic lifters vs solid lifters change anything. I read a lot about air being trapped in the oil with higher viscosity oil vs. better lifter stability at higher rpms with higher viscosity oil. any thoughts?
Lou
