Like Tree1Likes
  • 1 Post By Dan Case
Old 04-10-2017, 12:47 PM
Registered User
Cobra Make, Engine: Fairlane
Default Autolite C30f 9510 AJ
I am new to the forum and didn't see a Wanted section so I am posting here.
I have a K code 289 in my 64 Fairlane and need a C3OF 9510 AJ carburetor built in 1963. 1.12 venturis and auto choke.
Old 04-10-2017, 05:49 PM
LMH's Avatar
LMH LMH is offline
Last one I saw for sale went for about $2000.
I'm looking for a C4OF-AT for an original Cobra but have only seen one for sale in 10 years!
Rare carbs!
Alba gu brąth
Old 04-11-2017, 09:43 AM
Dan Case's Avatar
Original Shelby Owner
I have a 1964 production core that is missing the very rare brass spark vacuum port plug (which is actually a 1963 Galaxie part from the 2-4V induction system 427 engine package) and needs a good rebuild for use or restoration for show. IT DOES NOT HAVE AN ASSEMBLY TAG. The main body is one of the dated (on the bottom) ones from November 1963.
Send me a private message or e-mail with contact information and I will get some pictures to you.
Dan Case
Old 04-11-2017, 06:17 PM
Gaz64's Avatar
Shame you weren't looking late Feb.
Ford Autolite 4100 Carburetor C3OF-9510-AJ from 289 HiPo Fairlane | eBay
Old 05-17-2017, 01:19 PM
Registered User
Default Autolite Carb
I don't know how I missed this one. I did see it about a week after it sold. During that time I found a 63 dual point distributor and a 63 8K rotunda tach.
Old 05-17-2017, 06:31 PM
Dan Case's Avatar
Originally Posted by Gaz64 View Post
That one would be a lot of effort (time and money) to make mostly correct again.
- top cover from an application with a hot idle compensator
- service choke cap/heater
- no assembly tag (which is often the most valuable part)
Can't tell if it has the unique 1963-64 HP289 brass plug for the spark advance vacuum port that HP289s didn’t use (often missing or badly damaged)
It appears to have been commercially rebuilt in its past. If that is true I would wonder if the accelerator pump cavity filler is there and if the booster clusters are the correct ones.
On the plus side it is from the 1964 model year production time frame.
1985 CCX likes this.
Dan Case
