Old 02-20-2003, 03:01 PM
Send a message via AIM to ravedemon
Default the speed issue...
ok folks i'm comming closer to my decision....... i'm goin to go with a 351W crate engine rated at 405HP at the flywheel, alum. bell housing, centerforce dual friction clutch, tremec dual friction clutch, and a 3.55 or maby 3.73 gear......also i plan to put 18X10" wheelson the rear with 305/35/18 (or the widest or skinniest thing i can find).........what would yall say this thing is gonna run overall??????quater mile?????0-60 MPH???? any thought would greatly help..
thanks
Jason
Old 02-20-2003, 05:03 PM
Jeff Frigo's Avatar
Cobra Make, Engine: ERA 454 S.O.
In theory, 10.97 @ 124 mph assuming great traction which won't happen with street tires. In reality, probably more like 12 flat.
I used for 2,700 lbs including driver for weight.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
Old 02-26-2003, 04:43 PM
i olny weigh 130 lbs. so i should fly
