Old 03-04-2003, 04:24 PM
STEVE POTTS's Avatar
Cobra Make, Engine: Midstates, 427FE stroked to 482CI
Default Expansion tank
Anybody know how to modify a standard FE brass expansion tank so that it will bolt to a 351w?
Old 07-28-2003, 06:11 PM
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
cut the neck off, get a thermostat housing, figure where you want the neck on the tank, take it to a radiator shop, have them braise the new neck in the bottom where you want it and close off the old hole. Run a piece of rubber hose from the neck of the tank to the thermostat housing (90 degree works well). Wash, rinse, repeat. I did this - not the most fun I've had, but it worked. Took a P.O.S. FE tank from a 390 , had to do all kinds of body work on it, etc...but it looked perfect. For about a week, then we got air in our system and the thing came under serious pressure - more than the cap could vent, and we blew the tank up. It didn't separate, but it did round out real nice.
J.P.
Ohio Cobra Club
Token Gashole
Rate This Thread:
