Old 05-18-2003, 01:32 PM
Cobra Make, Engine: Kirkham 482 ci alum block
Default 351W vrs Sportsman Block
Hey everybody,
I keep hearing that the Sportsman block is either taller or wider or both than the Standard winsor block.
Is this True???????????????
I am having clearence issue for headers and engine mounts
Old 05-18-2003, 01:49 PM
Cobra Make, Engine: Levy Racing built FFR w/351W
Same dimensions.
Old 05-18-2003, 05:28 PM
Cobra Make, Engine: ERA 289FIA w/393 c.i. Windsor
Not true. Same dimensions.
Old 05-18-2003, 08:38 PM
Richard Hudgins's Avatar
Dave,
I personally do not know what the differences may be between a standard 351 and the sportsman block. It appears that deck heights can be different.
You may wish to look at:Racer Walsh
I can tell you that no one has had any problems fitting a standard 351 into the JBL chassis. Everytime a sportsman block is tried, there are header fitment problems and mount problems. (and it seems to be a deck height and mount location thing.)
Please note: I did not give you guys a bunch of extra room in the engine bay. (Someone might have tried to slip in a big block if I had left extra room.)
Therefore, something is different. I just do not know what it is.
I have not been able to get engine drawings from Ford on the sportsman block. No problem for the 302 and 351. but the sportsman unit is not available to me.
If you can find out the differences, I would really like to know.
Then folks could be informed of the differences going in, instead of having to dick around trying to make everything work.
Best regards,
Richard Hudgins
Old 05-19-2003, 09:24 AM
Originally posted by Richard Hudgins ...I personally do not know what the differences may be between a standard 351 and the sportsman block. It appears that deck heights can be different....I can tell you that no one has had any problems fitting a standard 351 into the JBL chassis. Everytime a sportsman block is tried, there are header fitment problems and mount problems. (and it seems to be a deck height and mount location thing.)...
Ford's catalog lists the Sportsman block as 9.5" deck Height. I know of no engine mount changes. There are also several other FRPP blocks that have a 9.2" deck height. But they are not the Sportsman blocks.
Is it possible that different heads were used on the blocks that had fitment problems? There are a lot of different heads available that use different exhaust ports, Yates, Brodix 200's, TFS Street Heats to name a few.
