Old 07-11-2003, 03:39 AM
GeorgiaSnake's Avatar
Cobra Make, Engine: Sold - Unique FIA - SA 396 Stroker
Default What have I got ?
Can any of you guys with the software that calculates HP / T tell me what my motor produces on paper. I'm curious because it seems much stronger than my builder told me it would be.
351 W Bored
Scat 3.850 Stroker (396 c.i.)
Ford D6OE Rods - ARP Bolts
Engine Tech - Hypereutectic Pistons 9.8:1
Hasting Molly Rings
Elgin E961P - Solid Lifter Cam
Ported & Polished Edelbrock Performer RPM Heads
Port Matched Edelbrock Performer Intake
Port Matched 1 1/2" Headers
Holly 3310 - 750 CFM
Roller Rockers
MSD & Modified Centrifical Advance Electronic Distributor
Thanks
Randy
Sold the Unique - Bought a Porsche TT - Sold the TT - Bought a truck
Old 07-11-2003, 05:24 AM
Ron61's Avatar
Question
Randy,
Could you give me the bore and stroke and also the cam specs, and preferably not the 50% ones but the seat to seat. If I know the lift, duration, and such my program will be pretty close except the torque will be low. The RPM it gives the power and torque at will be right on. I have a 50% spec convertor to convert to seat to seat but the different cams don't seem to use the same grinds so some times that is way off. If youy cam card doens't show the seat to seat then give me as close as you can the total lift and duration and I will see if I can make a close estimate.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 07-11-2003, 05:46 AM
hound dog's Avatar
GeorgiaSnake,
Without the cam specs. I have to make some assumptions (assume .500 lift I & E), but this gives me 427 hp at 5500 and 440 lb/ft torque at 4000. I could refine these numbers a little given the cam specs.
h dog
Old 07-11-2003, 05:54 AM
Cobra Make, Engine: 427SC Unique
Randy
I built a 351W Scat stroker for a friends Fox body street car last year and it pulled 442HP @ 6200 RPM. It was very close to your build except it had a Victor JR and a 4150 Mech 2nd .He is going to Willy's carb shop to put the car on the chassis dyno in Aug. I will send those #s if I can remember it.
Old 07-11-2003, 02:17 PM
From the cam card.
Cam Lift
Int. .320
Exh. .335
Valve Lift
Int .512
Exh. .536
Adv. Dur
298 Int.
308 Exh.
.050 Dur.
238 Int
248 Exh
Lobe Centers
Int. 107.0
Exh. 117.0
Adv. Timing
BTC 39
ABC 79
BBC 88
ATC 40
Thanks for the help guys.
Randy
