December 2025
Old 07-22-2003, 04:26 AM
TonyMadrid's Avatar
Cobra Make, Engine: A&C 351W, C4
Default Black Crinkle valve covers
Does anyone know of a source for black crinkle finish tall valve covers that say Cobra or Ford Racing? I called Summit and all they have are the standard height covers.
Tony
Old 07-22-2003, 07:07 AM
Cobra Make, Engine: KMP #248, 427 so, 4spd, 3:31 salisbury posi
are you looking for samll or big block valve covers? I have a new set of black wrinkle with 427 valve covers with "cobra" and "lemans" underneath.
Old 07-22-2003, 06:08 PM
jerry w's Avatar
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Default valve covers
Tony,
I saw some in a magazine add for a parts vendor: Try "Tony D. Branda Shelby & Mustang parts" www.cobranda.com/
I saw the pics of your engine, looks awsome! Where did you get the C-4 ? Did it fit the A & C body, or did you need to make modifications?
Old 07-22-2003, 06:12 PM
terry lee's Avatar
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
Tony,
Try Jeggs, or your local Ford motorsports dealer. They have the small block and big block covers you are looking for.
Check out my gallery, I have them on my motor.
TL
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
Old 07-22-2003, 08:16 PM
TonyMadrid's Avatar
Default Cobra Valve Covers
Thanks for the replies guys. I have a small block engine with roller rockers. I need TALL valve covers. The only place I have found them is at branda's. His covers come in a polished aluminum and the friend who told me about Branda said he black crinkle painted his. Ford Motorsports and Jegs don't have them for the small Block engine.
Jerry, I bought the C-4 from one of the guys in the Upstate Cobra Club. There is no problem fitting the tranny. When I ordered my kit I told them what engine (351W) and what tranny I was going to use. Idon't know if they make any modifications or if the kit will accept either a stick, a C-4 or a C-6.
Today I picked up my Intake Manifold. I bought a used Edelbrock Performer RPM and I had it powdercoated in a metallic silver, looks awesome. I'll post pics of it tomorrow.
Tony
Old 07-22-2003, 08:23 PM
terry lee's Avatar
Tony,
You can use the FE valve covers on small block heads.
There is an adapter made to accomodate the roller rockers and all. There was a thread some time ago with pix of the adapter and sales info. Maybe someone can remember where and when.
TL
BOYZ and TOYZ
Old 07-22-2003, 08:46 PM
Cobra Make, Engine: BackDraft - 351W and AOD
Default I used AL covers and painted them
Tony
I am also building a 351w and purchased AL covers and painted them and than used paint remover to remove the paint from the high points - i used an engine paint - but so far seem to work fine
jim
Old 07-24-2003, 01:23 AM
68gt500's Avatar
Cobra Make, Engine: Sorry "just" a 68 Shelby GT500
Send a message via Yahoo to 68gt500
Tony D Branda has the tall version of the black wrinkle Cobra covers. Give them a call.
Old 07-28-2003, 06:50 PM
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
If you like the look of the shorter covers, pull the baffles out of them, use a socket and a hammer to knock some depressions in for the rocker studs, and grind off all the casting crap on the inside. They're only a "little" too short to fit over rollers. I spent 2 hours working on mine (an hour a piece) and they fit fine over some big ol' rockers and studs. I like the look of the short ones and that's why I spent the time. But to each his own, for sure. 'sup to you, but you CAN use the shorter covers. Just takes a little massaging and coersion.
J.P.
Ohio Cobra Club
Token Gashole
