November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 12-01-2003, 07:23 PM
Club Cobra Member
Cobra Make, Engine: Hurricane Cobra - Keith Craft 428 stoker, 600 HP/614 Trq
Send a message via AIM to COACH MIKE Send a message via Yahoo to COACH MIKE
Rick:
I have a ford distributor and ignition box with an accel super coil. We turned the crank mechanically until both the exhaust and intake valves were closed. I checked the rotor to make sure it was just prior to the number one plug. I then checked the dampner and there was a scale unde the pointer. We marked the pointer at the 10 degree mark. Once the engine was started we ckecked with the timing light and found the idle timing at around 12 degrees advanced (BTDC).
How did you ck the timing advance? What procedure?
Thanks in advance.
