| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
01-11-2004, 10:19 PM
Cobra Make, Engine: not yet
Eleanor
If your thinking of building a tried &true 351w go with a combo that has been around since the early 70,s. A new SCAT 351 crank while it is castiron will handle more than you will be able to get out of it unless you are dead set on using a forged crank. With 6.125H-beam rods &JE 302 pistons,AFR 185 cyl. heads,576lift hyd. roller & victor jr manifold you will get about 470HP&over 450 ft. lbs. of torque. Just dynoed this combo last week & will be installed in car this week. I am sure the customer will love it .
Bobby
01-12-2004, 12:44 PM
FL
Cobra Make, Engine: no cobra, 71 Rx2 460windsor
I have to agree with Jack and Machineman, the 393stroker is just a great package all the way around. not to mention easier on the pocket book. If you have already bought the 6.2 rods and want to use them, have you thought about going with a 4.00" stroke?
01-13-2004, 08:32 PM
OH
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
V8-
I'm surprised nobody's busted out the "no substitute for cubic inches" adage...
HP is HP, but it is easier to build 500 of them out of 400 cubes than 351. Building a motor closer to the 400 cubic inch mark will get you the HP you are looking for. But as much as you keep asking about HP, my guess is you're going to be more satisfied w/ torque.
No matter what the technical argument is on the rod length, and who is right or wrong, a 6.2" rod is definitely overkill w/ a stock stroke. That being said, the stroker cranks aren't THAT much more than a 3.5" stroke crank. I DEFINITELY recommend the hydraulic roller cam for maintenance free power. My 408 has Comp Cam's XE 282-HR cam (can get you specs if you want) and the car will sit and idle at 400 RPM, rattling every single window in the house. We're running 10.25:1 on aluminum (AFR 185cc) heads and run CAM-2 because it smells good. It runs fine though on Sunoco 94.
Also be careful w/ the Octane booster and its "claims." They claim to raise your octane "up to" a certain amount - but that's when you use it on a very small amount of gas. I've heard some people say it takes several bottles to raise your octane even a couple of points.
Bottom line - having just gone through massive amounts of research wrapped up with a glorious day at the dyno - you just can't go wrong w/ cubic inches.
You are going to feel the torque - which unless you are trying to see if you can get your car into the 160mph range - is about all you're going to feel.
It sounds like with the heads you have, you would be super happy with a 393, hydraulic cam (look at the XE 282-HR or some a little milder or hotter), and 10:1 CR. You'd probably be making about 475HP and even more torque.
On a side note, I just ran my motor through desktop dyno. Amazingly, it is within 1 horsepower of our actual dyno run. It says 509. Although ours makes it at 5800 and this says 6500. But oddly enough our torque numbers are WAY off. We dyno'd at 544, and desktop is saying around 450-460. Wonder why...
OK I'm just rambling. Somebody pull my plug!!!
JP
J.P.
Ohio Cobra Club
Token Gashole
01-25-2004, 10:43 PM
MI
Cobra Make, Engine: 1990 408 stroker
I'M RUNNING 11.0.1 AND USEING 93 AND IT IS FINE 10.56 @ 127 MPH
01-25-2004, 10:48 PM
MI
MidOHasp WHAT IS THE COMBO ON YOUR 408, I'D LIKE TO COMPAIR WITH MINE.
03-17-2004, 12:32 PM
OH
solo408,
Sorry I never got back to you on this. I need a better way of keeping track of threads I get involved in.
What do you want to know about my 408?
J.P.
Ohio Cobra Club
Token Gashole
03-17-2004, 02:16 PM
Club Cobra Member
CA
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
solo408stroker,
How far is your timing advanced and what is the duration of your cam?
03-17-2004, 03:40 PM
AL
keep me posted
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
