November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-14-2004, 10:18 AM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
If your block will need clearancing depends on how much you stroke it. Clearancing the block is really not a big deal. Install the rotating assembly and oil pump (I have to clearance the oil pump a little also) and rotate slowly so you can see where you need to clearance, then go at it with a die grinder.
Here's a great place to get a stroker kit: AD Performance . Ask for Brian.
Pete
Rate This Thread:
