Old 01-22-2004, 05:36 PM
Cobra Make, Engine: 1990 408 stroker
Question help
i have a 408 stroker in a 351 w block. My question is this i want it to be EFI. I have trick flow tw heads with trick flow upper & lower intake 36lbs inj, 1.6 cran cams pro race rockers p/mounted. Will those heads work if i fully port them. im looking for around 450 to 540 rwhp. If not what heads/ intake combo could work.
Old 01-23-2004, 08:30 AM
V-8's Avatar
V-8 V-8 is offline
Cobra Make, Engine: 67 Mustang with Eleanor body kit.408w+250hp NOS with alcohol
Send a message via MSN to V-8
Hi guy;
TFS tw heads can feed a 408 stroker?
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
http://www.clubcobra.com/photopost/s...at=500&thumb=1
http://www.motorspor.com/index.cfm?f...r&haber_id=250
http://fordboss.blogcu.com/1967-must...leanor/5605130
http://www.auto-drom.com/haber-trtuning.htm
http://www.motorspor.com/index.cfm?f...&haber_id=1897
Old 01-23-2004, 05:15 PM
Cobra Make, Engine: KMP329 w/KC489 Shelby
The last few issues (the last 7 I think) of Muscle Mustangs and Fast Fords has done the most complete comparison test of SBF heads I have seen. They flow test and weight valve train components and then dyno all of the heads. The issues you would probably want to see are the last three or four. TFS heads were in their comparison.
Old 01-25-2004, 10:34 PM
SO WOULD THEY WORK
Old 01-26-2004, 12:58 PM
I might be mistaken, but I think this means YES.
This means there are a lot of others that will work as well.
