Old 03-18-2004, 05:08 PM
Default Stroker Kits?
Would you guys recommend DSS Racing or Coast High Performance for a stroker kit? Each have given me there best rotating assembly combo's for a '69 351w stroker which is listed below. This will be for a street car using AFR 185 61cc cylinder heads and a Eldebrock RPM intake. All parts are made by these companies. Please let me know if you have used these guys before. Thanks.
DSS: (408 Stroker Kit)
ProLite Forged Pistons (18cc Dish at 10.5:1 compression)
Cast Steel Crank (4.00 stroke)
Forged I-Beam Rods
CHP: (393 Stroker Kit)
Probe Sportman Race Forged Pistons Ultralights (15cc Dish at 10.1:1 comp)
Cast Steel Crank (3.850 stroke)
Forged I-Beam Rods
Old 03-21-2004, 01:46 PM
V-8's Avatar
V-8 V-8 is offline
Cobra Make, Engine: 67 Mustang with Eleanor body kit.408w+250hp NOS with alcohol
Send a message via MSN to V-8
http://www.cnc-motorsports.com/produ...300&CtgID=9059
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
http://www.clubcobra.com/photopost/s...at=500&thumb=1
http://www.motorspor.com/index.cfm?f...r&haber_id=250
http://fordboss.blogcu.com/1967-must...leanor/5605130
http://www.auto-drom.com/haber-trtuning.htm
http://www.motorspor.com/index.cfm?f...&haber_id=1897
Old 03-22-2004, 04:57 AM
jeffko's Avatar
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
I plan on using CHP for a 347 kit. They seem to be all over the Car Craft and Windsor build books.
Also, I have done a bit of research and I do not know how you came on AFR heads, but you have hit the best in my view. Checkout this article where they claim 100 hp increase with AFR heads.
http://www.carcraft.com/techarticles...ord/index.html
Old 03-22-2004, 05:47 AM
Don't know if you have already purchased the heads, but if you go 408, you may want to consider the AFR205s instead. Fast Fords and Muscle Mustangs has done extensive head test. You would want to see the Group III tests.
