Old 04-03-2004, 05:03 AM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
Default aluminum heads
Who makes the best Aluminum cyl. head for a 351w. Engine is for street and some track time.
Old 04-03-2004, 06:58 AM
Roscoe's Avatar
I like AFR's
http://www.airflowresearch.com
Roscoe
Roscoe
Old 04-03-2004, 08:15 AM
V-8's Avatar
V-8 V-8 is offline
Cobra Make, Engine: 67 Mustang with Eleanor body kit.408w+250hp NOS with alcohol
Send a message via MSN to V-8
I'm using TFS tw heads.It works good to 6500 rpm...
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
http://www.clubcobra.com/photopost/s...at=500&thumb=1
http://www.motorspor.com/index.cfm?f...r&haber_id=250
http://fordboss.blogcu.com/1967-must...leanor/5605130
http://www.auto-drom.com/haber-trtuning.htm
http://www.motorspor.com/index.cfm?f...&haber_id=1897
Old 04-05-2004, 04:26 AM
Cobra Make, Engine: None Yet
AFR
auto10x
Bill
Old 04-05-2004, 05:01 AM
Cobra Make, Engine: Porsche 928 S4
The only head that might be better than the AFR's is the Trickflow "R" (not standard twisted wedge) head when used on a big serious motor but they have unique exhaust ports that you would have to make headers for. For a 351 cu in motor I would go with the AFR 185's or 205's if your motor is a little bigger. If you can find any MM&F magazines from late last year, they had some great head tests with flow and dyno numbers.
BTW, I have AFR 205's and they have ports that are larger than a Victor jr's runners. They also have an extra set of exhaust tapped holes to be able to make headers that don't have to narrow down to fit by the stock bolt locations.
Old 04-05-2004, 05:32 AM
Rick Rockey's Avatar
Cobra Make, Engine: spf 351W stroked to 427
I'm running a 427 stroked 351W using Pro Topline's Cyclone aluminum heads. 64cc chambers, 215cc intake runners. Seem's to be working o.k. At one time asked for feed back on them but never got a reply, but you might look into them as a nother option, everthing bolted right up.
Old 04-05-2004, 06:46 AM
Cobra Make, Engine: no cobra, 71 Rx2 460windsor
Send a message via Yahoo to brainsboy
Rick, Did you dyno your motor with the Pro Topline heads? Im curious what kind of HP your making with those heads.
Old 04-05-2004, 05:26 PM
brainsboy, The only #'s I have at this time are from computer Dyno2000 Version 3.10 and the #'s are max. torque 539 @ 4500 & max power is 529 hp @ 5500. So for now my rev. limiter is set at 6000. I only have 700 miles on this motor, my other motor was a 351 / 385 hp svo.
Rick
Old 04-06-2004, 06:18 AM
What I like about the protopline heads is that they use the 3" exhaust spacing and have very thick castings, I opened up the exhaust ports on my set to 1.750 and made custom header flanges so the exhaust header blends perfectly into the exhaust port.
Old 04-06-2004, 07:17 AM
Cobra Make, Engine: BDR 89 KEITH CRAFT ALL ALUMINUM 427 WINDSOR
I like AFR 225
Mild street roller-576 lift, 10.5 compression, out of the box 225 heads==612 horsepower==615 torque on dyno, on pump gas.
427 windsor
DON
Mr.Fixit's Avatar
Large runners are not everything guys, velocity is king. Depending on your combination, and intended operating RPM, smaller runners can make more power, especially if you are not spinning it up to 8,000 RPM. Talk to your engine machinist/builder for advice, experience really counts when picking a combination of parts.
Old 04-06-2004, 07:56 AM
CobraEd's Avatar
Default These heads look "Way Cool"
I don't know of anyone who uses these, but on paper they look great. The best of all worlds. Small ports for good velocity, low end torque, yet higher overall flow than any two valve head, plus the perfect center plug configured combustion chamber. AND, . . . . . Everything bolts up to all the stock "stuff".
I would love to know of someone who actully uses them to know if they are as good as they sound. My Northstar Caddys are little 4.6 liter engines, and with their four valve heads, they haul ass. Same should apply with these heads.
Here:
http://www.araoengineering.com/Ford/frdsmb.htm
Ed
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
Old 04-06-2004, 11:42 AM
I just looked at those heads nice but looks expensive. What a neat design though. 400cfm at .500 lift.. I would like to see the dyno results at low rpms, it would be interesting to see if these would be over kill on a street car.
Ben
Old 04-06-2004, 03:22 PM
Mr.Fixit's Avatar
They came out with the small block chevy 4 valve heads over ten years ago, I still haven't seen them in anything other than a magazine article.
Old 04-08-2004, 11:06 AM
Well, I called them and the basic set of heads costs 5,200. Stage 2 heads were 5,400.. A little pricey. I think I would rather have an aluminum block at 3,200 before those heads.
Old 04-08-2004, 12:30 PM
Roscoe's Avatar
The AFR's are all billet CNC machined and ported for around 1300 bucks.
Roscoe
Roscoe
Old 04-08-2004, 01:12 PM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
I run the same head as Roscoe (58cc 185 AFR) and could not be happier. Beautiful workmanship and bested the GT40X heads by 50 hp.
