Old 05-03-2004, 03:13 AM
Default Priming Oil System on 302
My Car has stood for quite a while and I think it might be a good idea to prime the oil system. A couple of questions before I pull the distributor are: what direction does the oil pump drive turn? Is it possible to lose the drive spindle into the oil pan on a small block? Is the oil pump drive spindle 1/4" at both ends or 5/16"?
Thanks
Andy FIA
Promoting 289's in a country awash with 427's
Old 05-03-2004, 04:39 AM
Cobra Make, Engine: Porsche 928 S4
It turns counterclockwise. 5/16 hex. Yes, if you lifted the drive shaft as you withdraw the socket, it could fall into the pan. A little caution is all you need though. It wouldn't hurt to clean out the socket so that it can slide off easy.
Old 05-03-2004, 05:57 AM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Why not just turn of the ignition system/ pull the coil wire/ and spin it till it shows pressure. It should not take long and you will not have to retime the engine or worry about getting it 180 out or worse yet dropping that little socket down inside the engine!
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 05-03-2004, 06:25 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Bruce makes an excellent point.
Unless you are thrilled with the idea of pulling the distributor, setting the timing and running a drive down, into the engine, why not pull the coil wire and just turn it over for a minute.
Easier than the later.
Just my $0.02
Old 05-03-2004, 10:20 AM
Thanks guys, I may just pull the coil wire, I suppose there is no load on the bearings until the engine fires.
Andy
Rate This Thread:
