Old 04-28-2004, 03:38 PM
Default FMS 347 - AFR heads?
Anyone know what the hp and tq figures are using AFR heads on a Ford crate 347?
Ford claims 450 hp and 400 lb-ft.
Would AFR heads boost these figures?
Old 04-29-2004, 03:56 AM
DAVID GAGNARD's Avatar
Scalps; Go to the AFR site here http://airflowresearch.com/ and check out the Ford smallblock dyno #'s.You may be surprised to find out what kind of hp and torque they made,they give all the specs for each engine combo..... Right now,looks like AFR heads have all the others covered............
David
DAVID GAGNARD
Old 04-29-2004, 02:54 PM
David,
Thanks so much for the link. Great info here. This is what I was looking for.
Old 04-29-2004, 03:08 PM
Scalps;
Glad I could help,that's what this club is all about........
David
DAVID GAGNARD
Old 04-29-2004, 05:54 PM
Default AFR heads
i have attached the spec for my 351-> 408 stroker with AFR205 heads. I would suggest if you want to compare options use desktop dyno. The numbers will be at the flywheel and are only as good as the data you enter, however it is great for looking at relative results
Old 04-29-2004, 05:57 PM
Default AFR heads with attachment
Looks like the PDF file was not attached. I'll try again
Old 05-04-2004, 10:21 AM
peterd,
Wonderful. Wonderful! Thanks so much for the PDF Dyno information. Wow, 434 lbs-ft at 2000 rpm!!! Geez! How's your neck?
KW
