Old 05-15-2004, 11:31 AM
Default Fuel Pump cut off switch - help please
I am connecting my electrical fuel pump via an oil pressure safety cut off switch and need to clear up some confusion with the wiring diagram.
The diagram shows one of the swith terminals wired to the ignition and the other wired to the starter with the main feed going to the fuel pump +
Is this wiring on top of the existing wiring to starter motor and coil or does this replace the original connections. Allso anybody know which terminal on the Chevy starter it is meant to connect to as it does not make this clear.
Your help would be much appreciated.
Cheers Guys
Mike
Mikey B
Old 05-15-2004, 12:14 PM
Here is a best guess without seeing the wiring diagram. The challenge is that when the engine is first started the oil pressure is assumed to be "0"psi. You need a way to get the pump running while cranking the engine. The connection to the starter should go to the solenoid side of the starter. This provides + 12v to the pump positive terminal during cranking. This effectively bypasses the safety cutoff switch during starting. Once the starter solenoid is released and the starter disengages from the flywheel the oil pressure safety switch is back in the circuit. Assuming now you have adequate oil pressure the switch will supply power to the pump and maintain pressure in the fuel system. One additional safety feature I used in my wiring is to use a fuel pump relay to cut down on the heavy guage wiring required and wired the circuit described above into the control side of the relay. Lastly the factory Mustang used a roll over switch that has a NC(normally closed) set of contacts when the car is upright. If you should ever roll the car the switch opens and the fuel pump is automatically cutoff reducing the chance of a fuel spill and fire.
Old 05-15-2004, 12:50 PM
Thanks for the info. Sounds spot on.
Mike.
Mikey B
