Old 05-31-2004, 07:52 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Default Oil capacity for a 302?
I have a fox body oil pan, no oil cooler. Chilton book that I have says 5 quarts but the stick is saying that it is overfilled. What is normal for this setup? Gauge reads about 60psi at startup and drops off to about 45-50 after warm-up. Dip stick is correct for this engine and is seated properly in block.
Thanks
Trueoo7
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 05-31-2004, 08:39 PM
Cobra Make, Engine: Johnspeed,408W,Tremec 600 roadrace, Liquid Yellow w/Black stripes
Trueoo7,
Where is your dipstick located? With the fox style pan it should go into the engine on the drivers side, to check the rear sump. I found this out the hard way. My dipstick went in at the passenger side of the timing cover and only measured the front sump. Thats for older front sump pans. Drained the oil and only 1.0 quart came out of the rear sump. Hope this helps.
Ted.
Old 05-31-2004, 11:20 PM
Rick Parker's Avatar
I think it is 5 qts incl filter?
Rick
Old 05-31-2004, 11:29 PM
5 gts, including filter is CORRECT! NOT uncommon for dip sticks to measure incorrectly. I never assume it is "accuarate". I try to determine the correct amount of oil for the engine in question and mark the dip stick accordingly.
My 427 side oiler has a "Ford Van" oil pan which runs the same height from the front to the back of the engine. 9 qts with filter, dip stick marked accordingly!
,,,,kinda cool. The oil level just covers up the word "Safe" but only the SA, leaving the FE uncovered! The gods have spoken!
Old 06-01-2004, 06:40 AM
Cobra Make, Engine: FFR2229K, Vortech-blown 306 (446rwhp, 442 rwtq)
A stock fox pan has TWO drain plugs. Lots of folks miss the front one the first time or two they change the oil. That leaves about a quart of oil in the pan.
Wade Chamberlain
Old 06-01-2004, 06:52 AM
Cobra Make, Engine: FFR2479K, 351W yellow/black stripes
Never understood why Ford did that. Wonder how many Jiffy Lube oil changes were never done right for people....
Steve
www.midatlanticcobras.com
No, it ain't "real", but it's real fast....
Some people choose to rattle their windows with stereos and speakers... I choose to rattle windows with my right foot.
Old 06-02-2004, 08:21 PM
Nope, mine is definetly on the drivers side, which makes sparkplug #7 hard to reach or do a compression check, believe me I know, due to earlier problems I've had to change my plugs about 5 times already. (was running SUPER rich)
Well then 5 quarts it is and I'll mark the stick accordingly.
Thanks for the help !!
Trueoo7
