Old 06-11-2004, 10:12 PM
289FIA's Avatar
Proud Club Cobra Member
Cobra Make, Engine: ERA 2121
Post 302 (im)balancing question
I'm building a 85-up hyd roller 302 from the ground up. The crank and rods are original but will be balanced as a rotating assembly. Since I'm replacing both flywheel and balancer/damper, could I go with the 28oz option vs the original 50oz?
What are the advantages/disadvantages?
289FIA
Old 06-12-2004, 04:39 AM
Cobra Make, Engine: FFR4067, 393W
No, the '85-up 5.0 crankshaft is designed for 50 oz/in imbalance damper and flywheel. A good balance shop MIGHT be able to change it, at great expense, but WHY??
If you're looking at some other clutch assy besides the 10.5" diaphragm you can buy aftermarket flywheels with 50 oz balance that will accept several different clutches.
Ed
We used to own the government, now the government owns us. Where'd we go wrong?
