November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-04-2004, 06:21 AM
Cobra Make, Engine: In Limbo for the time being
Default Demon carb vs Holley carb
Jsut wondering which carb you guys have found to get better performance,ease of set up, and best overall luck with let me hear your opinions Thanks Chris
Old 07-04-2004, 07:01 AM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
I'm happy with my BG Mighty Demon, mechanical 750.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Old 07-04-2004, 11:35 AM
Old 07-04-2004, 04:14 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Never had a problem with a Holley. Most out of the box are very close and they are easy to tune and set up as well as overhaul when the time comes.
Must admit have not played much with the Demons but kind of feel like they are an "attempt" to improve the Holley style of carbs.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 07-05-2004, 05:40 AM
BMK's Avatar
BMK BMK is offline
What are the differences in cost and ease of set up.
Advantages from one to the other in set up?
Bernie
Bernie Knight
Old 07-05-2004, 12:55 PM
Bernie, the folks at BG will be the first to tell you that their carbs like lots of advance. I took delivery of my stroker with the Mighty Demon installed from the beginning. It seemed to be a bit rich so we reduced the jet sized on both primary and secondaries. It always seemed to run well (no hesitations, great idle, lots of power at WOT etc.) I finally took here in to a dyno tune shop where an additional 6 degrees if advance was added and the jets were returned to the values installed from the factory. Since the carbs are configured per the specifics of your engine and flow tested prior to shipment, they seem to get it pretty well "spot on" out of the box. Might need a little bit of distributor-twisting to get it all set up. Several of the local guys have yanked their Holleys and replaced them with Demon carbs. BG has a good name around here.
Old 07-05-2004, 02:35 PM
Tongue Pirate's Avatar
I've used both Holley & Demon. They are both great carbs but Demon has a competetive edge as it was designed to be a better "Holley" out of the box. For vintage looks I go with the Holley. Anything else I like the Demon. Performance wise the differences are minimal in the seat of the pants but as we all know in racing sometimes you can't feel a tenth of a second. That said there are a number of aftermarket Holley's that will stand up to or possibly exceed any Demon in side by side testing.
Hyde D. Baker
Old 07-06-2004, 08:03 AM
Roscoe's Avatar
It's interesting to note that the same thread is going on over at the FFR forum with complete opposite results. Most over there favor the Holley while most here the BG. Don't know what the hell this means but curious anyway.
I love my BG.
Roscoe
Roscoe
Old 07-06-2004, 09:40 AM
Clois Harlan's Avatar
Me too Roscoe! Terrible gas mileage but I love the performance of my BG Speed Demon. Pretty darn snappy.
Clois
"Let's roll"
"Be part of Something Good
Old 07-08-2004, 07:49 PM
Cobra Make, Engine: FFR Carbon 320 AFR
Hi Clois
I have been using Holly HP's with no problems. I wanted to use the Demon line because they sure appear to be better but three differend engine builders that I respect all said that the Holley's make more power on engine dyno's.
Hope to se you at R&G in Sept.
John
