Old 08-13-2004, 12:24 PM
Default "Proper" orientation for #1 plug wire?
Hi guys,
Please bear with me for just a few more stupid questions. This IS my first Ford, remember.
I'm used to Chevrolets and having the #1 plug wire on the distributor oriented to the front of the engine. On my 289, the #1 wire is roughly aimed at the #5 cylinder. Is this "correct?" I ask because I'm replacing plug wires and re-curving the advance anyway. I figure that if I'm going to have it all apart I might as well take a minute and point the distributor in the proper direction.
Thanks, Tom
Old 08-13-2004, 01:27 PM
http://summitracing.com/tech/charts_...arts_flash.htm
John FFR2457K
Old 08-13-2004, 01:28 PM
Mr.Fixit's Avatar
The #1 cylinder on any engine, is the one furthest forward.
as to which lug on the distributor to assisn as the #1, whatever you like for routing the wires. You don't have to use the lug that is often marked #1 on the cap.
Old 08-13-2004, 03:43 PM
J Marshall,
Thanks for the link. I knew which cylinder was #1, and obviously I can stick the distributor in any old way I please and route the wires accordingly. But I figure that if I'm going to do it, doing it right makes sense. Seeing the chart on Summit's site, I can see that the P.O. wired it up incorrectly. But without the chart, I would have also!
Thanks again, Tom
