Old 11-03-2004, 02:51 PM
Default Oil Cooler hoses and fittings
Original competition 289 and 427 cobras had black oil cooler hoses and fittings that were polished stainless or aluminum or something like that.
Was the black hose used simply rubber "heater hose" or was it something else. If it is a specialied hose, could someone direct me to a source of something close to it. I prefer not to use the stainless braided hose to keep the more original look. Also, I am trying to find a source for the fitting. I prefer not to use the red and blue anodized fittings, but it seems like that is all I can find.
Thanks,
Mike
Cobra Pack
Old 11-03-2004, 04:25 PM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Mike:
The hose and fittings were Aeroquipt stainless braid re-inforced
aircraft medium pressure hose and fittings. The fittings were cad plated steel. I think the hose is #303. Should be available at most
airport repair shops, or do a web search for "aircraft hose/fittings"
BTW the wire braid on these older hoses was covered with fabric reinforced rubber.
Ted
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 11-03-2004, 05:04 PM
Gatorac's Avatar
Cobra Make, Engine: BDR 930, 427 Windsor T56
Summit or Jegs carry the AN fittings that are nickel plated. They look just like stainless.
You may also want to check with your local Parker hose and fitting supplier. They have steel fittings and several different hose options. You should be able to locate a local supplier here.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
Old 11-03-2004, 06:13 PM
RACER X #99's Avatar
Mike, Look for a supplier in your area that makes up hydraulic hoses. They can make just what you are looking for and a lot cheaper than the race catalog co. ie Jegs, Summit. These companies use JIC fittings which are similar to AN only stronger and a lot less expensive.
Old 11-03-2004, 07:06 PM
What is the outside diameter of the hose used?
Mike
Cobra Pack
Old 11-04-2004, 05:05 AM
Big-Foot's Avatar
Cobra Make, Engine: RCR GT40 #45
Check out Fittings and Adapters prices for hose and JIC fittings here:
http://www.fittingsandadapters.com/
I have bought a ton of stuff from them. Their prices are good shipping is quick and inexpensive. They are very responsive - even to small orders.
If you want to be totally 100% "real", you will buy fittings that are BSP (British Standard Pipe) which is what most of the originals used. That being said, you would be hard pressed to tell the difference visually between AN/JIC and BSP.
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
Old 11-04-2004, 09:31 AM
Send a message via AIM to Ted Heffernan
Default Oil oolers & Fittings
A great source for original Mocal coolers and cad or nickel plated fittings & black or silver braided hose is BAT, in Sarasota, Fl at 941 355 0005. Ask for Eric. They also import Sachs shocks.
Old 11-04-2004, 10:02 PM
Rick Parker's Avatar
Default Good Earl's Source
http://www.amstreetrod.com/CatalogIndex.php4
This is a very good souce in the Sacramento area.
Rick
Rick
Old 11-05-2004, 12:36 AM
BMK's Avatar
BMK BMK is offline
My oil hoses are 7/8 external - braided.
Bernie
Bernie Knight
Old 11-05-2004, 08:50 AM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
Good source for aircraft bolts, fittings and parts: www.aircraftspruce.com You can order via the website
Rate This Thread:
