Old 12-05-2004, 04:37 PM
Thumbs up SBF302/5.0L help
Hello to all: I'm new on this forum,I have read lots of good info in this forum and I think is time 4 me 2 ask for your help with my project.I'm working on a frame off rest on 60 F100 with many mods,one of them is the engine.Have a 87 302 roller out of a truck would like 2 convert it from FE 2 carb,my intensions with this truck is for street most likely weekends with enought power to get me out the hole when need to .the following is a description of what I got:
87 302/5.0L roller w/flat pistons
edelbrock performer rpm air gap
set 91 ho mustang heads
also set of 351W D00e heads (optional)
which of this heads make more power?
what roller cam/lifters is the right one to use? carburator?distributor? thankyou in advance for all the help i can get happy holidays,ford4ever
Old 12-05-2004, 06:41 PM
Big-Foot's Avatar
Cobra Make, Engine: RCR GT40 #45
The D0 heads are the ones to use. Carb - I would probably use Holley 750 CFM Vac secondary List-3310 for performance or a 600 CFM Vacuum secondary LIST-1850 for street.
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
Old 12-11-2004, 08:52 PM
Hello Randy: thanks for replay,which cam you recomend? e-cam is a good choice on this application?
Old 01-02-2005, 06:33 PM
Cobra Make, Engine: 68 GT 500 convt, 428 Cobra Jet
Talking Cam?
Hey;
I have a friend with a similiar setup. He went from a E303 to a X303 because he wanted more power but still planned on a street car.
Good Luck
Old 01-07-2005, 06:05 PM
Ok, got that;302 air gap intake is ok??? Valve springs???
Rockers ratio??? Tks
Old 01-07-2005, 06:34 PM
HighPlainsDrifter's Avatar
Arrow 5L
Hi,
You need to use a '85 duraspark distributor , it has a steel cam gear for the roller cam. A 'E' cam would be better with a performer rpm for a street aplication. 1.6 rockers are standard for a small block.
Good Luck,
Perry.
Old 01-07-2005, 07:32 PM
Cobra Make, Engine: BDR 302 AFR 165
MSD ready to run Distributor is nice set up and easy to hook up. I would use a Comp cam around .515 lift and 220 duration at .050. I used ford motorsport rockers adjustable stud mount because at the time summitt had them on sale. let us know how it runs when you get it together.
later dennis
