Old 12-29-2004, 09:03 PM
Default 289 stroker?
Whats the most a 289 block could be stoked too without getting the piston pin into the oil ring area, i theres problems when stroking a 302 - 347 and a shorter rod has to be used.
Adrian
Old 12-29-2004, 10:00 PM
You can stroke a 289 just as you would a 302 safely to a 347 with no problem at all. Get the book on How To Build BIG- INCH Small Blocks by George Reid. The book lists around ten different co's with stroker kits.
Tim
" It ain't no big deal"
Old 12-30-2004, 04:47 AM
The books I have read advise you not to stroke a 289 very far due to the fact that the cylinder skirts don't extend down as far as a 302 does. You could get lots of slap by doing that.
Old 01-02-2005, 06:14 AM
Cobra Make, Engine: FFR MK III
I second that. I have the book by George Reid and the skirt issue is addressed there.
FFR MKIII Build in progress - Dart 427W, Stack injection, TEC3, IRS.
Old 01-02-2005, 06:26 AM
Not only that, but the best thing about the 289 is it's ability to handle high RPM's due to it's short stroke. Personally, I'd track down a 302 block (Very plentiful) and stroke it before I'd do a 289. Save the 289 block & crank for a screamer.
Old 01-02-2005, 07:38 AM
Cobra Make, Engine: Superformance #1374 with 392 RDI Stroker
I looked into this when I had a 63 Fairlane sports coupe. I found a 1965 289 block and considered stroking it. I talked to about 4 engine builders and they all agreed to leave it alone. The skirts are too short. I agree with tpiini about leaving it stock (maybe a thin bore) and making a high RPM screamer out of it. Get a newer 302 and make your 347 if that's what you want to do.
Just my 2 cents
Mark
Old 01-02-2005, 05:13 PM
Cobra Make, Engine: 68 GT 500 convt, 428 Cobra Jet
Default Stroker
Hey:
I got a 347 stroker for my 65 fastback and this guy that built it said that was about as much as it would go. Ask somebody else and they say different.
Old 01-22-2005, 12:53 AM
Cobra Make, Engine: genuine 289 cobra (cox 6013)
Adrian
Have built a 331 on 65' block,made 540 HP @7000 /440 lb torque on pump gas with Weber,no problem
Bernie
