Old 05-07-2005, 06:57 AM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
Default Timing
What kind of timing should you run in a 351w.Inital and total
Engine is 351w 9.5 compression/ Cam 230 duration @.050/.512 lift.
Old 05-12-2005, 08:17 AM
Terry Stapley's Avatar
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Default Engine Timing
On my 418W I am running 22 initial with a total of 36 degrees! The engine seems to like that the best!
10:1 compression
@ .50 / .512 Lift
Terry
Old 05-12-2005, 08:27 AM
On my stroker (392), I run about 20 initial, 32 max.... all in by 3000. No vacumn advance.
C/R = 9.7:1
Cam dura= 232 in, 240 ex. @.05 lift.
Lift= .566in, .576 ex.
PG Demon Carb
I'm very happy with everything this way.
Old 05-12-2005, 10:25 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I have a cleveland, but have the same specs as Terry does. My CAM has a bit more lift.
Idles about 1100.
Old 05-12-2005, 11:10 AM
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
When running 20 deg initial, are you having starter,kickback problems when starting hot? engine runs and spools up quickly at 20 or 22 deg but stalls the starter when hot. It won't turn over relaibly hot at anything over 17 deg. Ideas?
gn
Old 05-12-2005, 11:17 AM
trularin's Avatar
Member of the north
I haven't had a problem, however, I understand that the MSD 6AL or something like that, retards the timing on start up for just such things.
You might want to look into that. I know Rick Dorman has just put on on his car and says it was a good upgrade. I am considering it.
