Old 05-31-2005, 07:30 AM
V-8's Avatar
V-8 V-8 is offline
Cobra Make, Engine: 67 Mustang with Eleanor body kit.408w+250hp NOS with alcohol
Send a message via MSN to V-8
Default Auburn Gear Performance Differentials
Hi guys;
I'm using 8" 28 spline Auburn Differential lock #542059. I have some problems with traction and i notice that right wheel spins more then other. So i had sent an e-mail to Auburn Gear Performance Differentials.And>>>>
> Hi;
>I'm running with #542059 differential lock 28 spline.But in these days it
>started to fail sometimes.No noise in differential.Right wheel spins more
>then other.I'm planning to order your service kit
>#541023,#541015,#541010.Can i learn the prices and can i find them in
>Summitracing?Thanks...
>From: "Auburn Gear Performance Differentials"
>To:
>Subject: Re: ford 8 inc
>Date: Wed, 04 May 2005 06:35:14 -0500
>Good morning,
>Thank you for using our product. First of all, let's determine if the unit
>is functioniong at all. To find this out, you will need to do what we
>refer to as the "break-away torque test." To do this, jack up one side of
>the rearend, put your transmission in neutral and use a torque wrench on a
>lug nut of the wheel that is off the ground. Turn until it breaks away,
>the Ford 8" should measure around 60/80 lb. ft. of torque. If it is much
>different from this, you are looking at purchasing a new unit. We do not
>offer a kit for the side gears but we do have a program in place called the
>D-Rex Program. If you have one of our units and it is not more than 4
>years old, you will qualifiy under this program. Give us a call at
>260-925-3200 to determine if you have a unit that qualifies under this
>program.
>We do not sell direct through Summit but we do sell to Jeg's.
_________________
ATAY AYDINER...
_________________
ELEANOR
[url]
http://www.clubcobra.com/photopost/s...at=500&thumb=1
http://www.motorspor.com/index.cfm?f...r&haber_id=250
http://fordboss.blogcu.com/1967-must...leanor/5605130
http://www.auto-drom.com/haber-trtuning.htm
http://www.motorspor.com/index.cfm?f...&haber_id=1897
