Old 06-03-2005, 07:32 AM
Dominik's Avatar
Default 351W vs. 60s 428FE
dear engine builders,
did anyone run a comparison of the torque curve from a 60s FE to a 351 or 392 from FORD motorsports?
I wonder if the "FE" engines from then are not much better in torque then todays free flowing aluminium headed units of the "W" family.
a Desktop Dyno simmulation may provide the first indication, but I don't have the cam data and don't know how high to rate the aluminium cylinder heads..
maybe one of the magazines did a dyno run of the 351 and 392, so we only need one from the old BBs to compare.
I am not after which maxed out engine is better, let alone SB vs. BB... - please ;-)
cheers,
dominik
If I don't respond anymore, that's because I can't log in
Old 06-03-2005, 09:17 AM
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
Dominik,
Depends on the trim level of that 428!
A friend of mine has a 427 SO with a 428 crank (454 ci) and I have a somewhat hairy 408. Mine makes more HP and TQ than his (slightly), but his torque curve starts quite a bit earlier.
The torque curve of a Windsor based motor, especially a stroker, can be made to be pretty flat and wide. But it will always be difficult to duplicate the torque curve of a BB with a SB, especially if that SB is meant to make any kind of power at any kind of RPM.
I guess the question I'd need answered to provide more info is what is the HP of each engine in question, and where does that HP peak? That will tell a lot.
J.P.
Ohio Cobra Club
Token Gashole
Old 06-03-2005, 11:24 AM
Dominik's Avatar
Hi,
this is what I want to tell, if it proves to be correct:
a current 351W from FORD motorsport (crate) makes more torque and hp than a 60s stock 428, as delivered for the Cobra (or "stock" 427).
cheers,
dominik
Old 06-03-2005, 11:44 AM
A 392 maybe, but even then I don't think so.
Didn't the "stock" 427's make 475HP?
351W crate from FMS is 385 HP. I think the 392 is 450 or something. 425?
I'm pretty sure the "crate" SB's are not making more HP/TQ than the "stock" BB's of the 60's. I could be wrong. It happens a lot.
But I think to make a SB with more HP/TQ, you have to go beyond the FMS catalog.
J.P.
Ohio Cobra Club
Token Gashole
Rate This Thread:
