Old 06-04-2005, 07:09 PM
Cobra Make, Engine: factory five roadster with a stock 87 302
Default 302 ho valve adjustment
I have an 87 302 ho with hyd roller lifters.Do you tighten the stud bolt to a specific torque and measure clearance and adjust with longer or shorter push rods or adjust with the stud bolt.
Old 06-04-2005, 07:11 PM
The studs need to be torqued....
If your rockers are not contacting the pushrods correctly, then you'll need to get a adjustable length pushrod and check it....
Old 06-04-2005, 07:27 PM
Thats what I thought.Thanks for confirming it. I,m getting a pop out of the drivers side exhaust and thought I may have a valve not closing.
Old 06-04-2005, 11:21 PM
G.R.'s Avatar
Send a message via Yahoo to G.R.
Are you sure you don't have a leak on your header gasket or collector gasket? Is the "pop" under acceleration or deceleration?
I thought my "pop" was valve related but it turned out to be a leaking header gasket on the passenger side.
Old 06-05-2005, 04:23 AM
G.R. has some good points to check....also....is the car carbureted or fuel injected? You could have a rich/lean condition on that side....
Old 06-05-2005, 07:33 PM
Car has the factory fuel injection.It pops when I push the clutch in to shift.One pop like a firecracker in the exhaust.I thought I would do a compression check and replace the header gaskets on driver side.Hope it's a gasket.
