Old 08-08-2005, 06:25 PM
Cobra Make, Engine: Unique FIA, 425 Windsor
Blykins,
According to my numbers from the chart, link on page one, the GT 40X heads flow 214int and 149 exh. Can you run those numbers through your desktop dyno, my PC with the program on it has crashed. Also, can you run my Avenger Heads through it?
The Avenger head flows 327 int and 247 exh. The cam is 246int /254 exh and .622/ 637 lift at 50 with 112 degree loab speration. This is a hydraulic roller. Also, I find that if you pick the dynomax ultraflow mufflers and 3 1/2 exhaust in Dyno 2000 we get closer to the real flywheel horsspower.
