02-22-2006, 10:54 PM
qld
gt40 alloy heads, valve spring problem
need a bit of help with a problem ,it seems the valve springs that came with the heads are weak and motor has a power dip at high revs (around 4500-4800 rpm) this shows up on a dyno , it also seems to have a flutter (only word i can think of) when you excelorate and back off a little . a couple of mechanics and the 2 dyno guys say its the valve springs. of course ford motorsport say they dont have problems with there springs and wont replace unless i prove which ones are failing , so my question for you folk out there is 1 : have any of you had probs with the same 2 : should i use another type of spring from someone else,.
any help would be appreciated .
darren
02-23-2006, 08:00 AM
What cam are you running?
'89 LX 408...SCAT, Probe, AFR 205, Vic Jr, Pro-Systems, Rawls sft cam, UPR K & arms w/coil overs.....more to come!
02-23-2006, 06:58 PM
That's a relatively mild cam with a peak rpm of 5100.
Have you/mechanic/dyno guy verified the valves are properly adjusted?
02-23-2006, 07:53 PM
BC
B303
Hi,
I ran the B303 cam with stock springs for 3 years,works fine,the cam only makes power to 5,200 rpm.
I would check the distributor advance rate.
Good luck,
perry.
02-23-2006, 08:10 PM
qld
thanks for the replys ,as for your questions every electrical part has been replaced and adjustments checked several times ,  very frustrating
02-24-2006, 07:06 AM
At this point, pulling the springs and checking their tension would seem the only way to verify that was the problem. Or eliminate them as the problem.
