Old 03-29-2006, 07:56 AM
Poolw's Avatar
Cobra Make, Engine: SPF, KC 427
Default Changing from stock springs & shocks to coil over?
I have a LA Exotic (now caled B&B) with a Mustang II front end and a 351w. The ride is extremely hard and I would like to know if I change it to coil over can I expect a big improvement. Is its a big job to make the change from springs to coil over? Has anyone done this before? Any and all advise is appreciated.
Old 03-30-2006, 03:24 AM
JCoop's Avatar
Cobra Make, Engine: Superformance, FRP460 Big Block
Maybe you can give us more info on your current suspension setup. But in general, I think the coilover systems do a better job and saves weight. As an alternative, you can change the current springs to ones that have a lesser rate. IOW, it may be that the ones that are installed now are too heavy. I think you can get them in different rates. I know that with coilovers, you can get the springs in a whole variety of spring rates. I changed my rear springs from 450 lbs to 375lbs and made a world of difference. I also changed the swaybar bushings to poly all around.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 03-31-2006, 07:59 AM
A lot of the impact harshness comes from the shock. Which shocks do you have. No Cobra experience, however I've found that a "sport" Bilstein can ride better than a factory shock, while having greater wheel control.
Old 04-07-2006, 09:48 AM
Poolw's Avatar
I have standard Mustang II spings front and rear with Monore shocks. The shocks good like new but are orginal when it was build it 94.
