Old 04-13-2006, 05:16 PM
Cobra Make, Engine: Unique 427SC/331/5 forward
20% failure rate..........wow. Wonder what happened.
Can't speak to any other, but I bought a Ford crate 302 and have put nearly 9000 miles on it without any issues whatsoever. It is the 302/345, B cam. Starts immediately, runs excellent and is carbureted. $2900 delivered to my door. As mentioned before, the early 392's had piston troubles but seem trouble-free since the change to forged units.
Alternative might be to get a custom shortblock from the many builders out there and some good heads; pretty easy to put together, even for a novice.
Just remember, with ANY engine, to prime it extensively before you go to crank it up.
Old 04-13-2006, 05:32 PM
CobraKid427's Avatar
Cobra Make, Engine: Shell Valley, Keith Kraft 427FE Stroked, Tremec 5 spd
Send a message via Yahoo to CobraKid427
Just buy a Keith Craft...its a no brainer.
Old 04-14-2006, 12:11 PM
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
I got a 351w crate engine. I've had no problems and no complaints, just a happy camper.
David
Old 04-14-2006, 06:13 PM
Cobra Make, Engine: Superformance (SPF2265) 482cu, Tremac TKO 600R
Default Ford Racing Crate Motors
My crate engine looked fine in the box but when unpacked we noticed the inlet manifold was not sitting properly on the gasket. We removed the inlet and found that it wasn't port matched to the SCJ heads (out about 25%). We decided to dig a little deeper and upon removal of the heads we found all eight bores rusty. Dig even further we found the crank miss-aligned and the big end bearing toast. Add to this the wearing cam problems; all summed up to a total and complete rebuild. I was lucky that the budget extended to a rebuild and now have a great engine that is extreamly strong with forged components and roller rockers etc etc. In hind site, when you purchase these crate engines their wacked together by semi skilled labour with no passion, fine if you just idle the streets but if you want the occasional track and drag then look to something better enginered. Remember, these things will need fuel systems, alternator, decent sump (although I note the new engines now have better sumps) so it all adds up. Do the sums as to the total cost of a crate motor compared with RDI/ KC/ Roush etc, if you want a turn-key engine with the right documentation I don't think you would regret spending a little extra on one of those.
Regards
Bruce A
Old 04-15-2006, 04:21 AM
427SnakeSC's Avatar
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
Last fall, when I ordered my 427SO from Keith Craft, I went down to Arkansas to visit him. He spent most of a day with me, giving me a tour of the plant and asking how I was going to use the motor. He is a great guy and very easy to talk to. Great people to deal with! From what I have heard from other customers, here on this forum, he stands behind his motors, 100%! Go for a tour of the plant, before you make up your mind! You won't regret it!
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
Old 04-15-2006, 08:40 AM
Jake's Avatar
Cobra Make, Engine: Superformance Cobra #1628, Coast Performance Stroker 427W Ford 520HP/535FT.TQ, Blue with white stripes
I have the SVO 460 in my Superformance and it has been great. I have had zero problems with it and have about 11,000 miles on it so far. The SVO engineers said that it should be good for 100,000 miles. I feel that for what they cost, they are a bargain. I am surprised at the 20% failure rate.
Jake
Old 04-15-2006, 10:05 AM
Speedysnake's Avatar
Cobra Make, Engine: BDR - 351 / 385 hp
I have the 351 ci / 385 hp Ford crate engine. While I do not have a lot of miles on it yet, I'm quite happy with the performance. I can't help but wonder if that "20% failure rate" was some isolated incident in a particular engine set up. If anyone has more info on it, I'd like to know more about it!
Speedy
Old 04-15-2006, 02:45 PM
Cobra Make, Engine: SPF #1158, BDR #180
On mine (430HP 351W), they never provided a reason for failure. I had to have it pulled and shipped back to them for inspection. If they determined it wasn't their problem, I was going to be responsible for shipping costs. They determined it was their problem (apparently since they repaired it and covered shipping costs).
I haven't heard of any other with "catastrophic" problems.
Honestly, while I was upset about the failure I'm not sure I could have asked for a different outcome. Would other engine builders have covered removal / re-installation if they hadn't done the original install?
Old 04-16-2006, 06:11 AM
I'm very happy with my FMS 392 crate! It has over 10,000 miles, many auto-crosses and some track time. The rev limit is set at 6000 rpm and it gets fresh oil once a year.
For $6500....it has been an unbeatable value. Like the energizer bunny.....
Consider your budget.....how much does a custom built motor cost. When I looked 3 years ago, they seemed to be about $12,000-$15,000...which was way out of my budget.
Where are the 20% failures? So far, no one has posted with an actual failure....what broke, how did it break? How much did it cost to fix it?
For me....I would hesitate to buy another one....it has been everything I wanted and it left a cool $8000 in my pocket.
Good luck and have fun with your new car!!
Old 04-16-2006, 08:22 AM
Originally Posted by rob frink
...Where are the 20% failures? So far, no one has posted with an actual failure....what broke, how did it break? How much did it cost to fix it?....
Uh....I posted an actual failure. Cracked block. 200 miles. It cost removal / reinstallation cost.
Old 04-16-2006, 10:42 AM
ZOERA-SC7XX's Avatar
Crate engine is best unless you're doing SERIOUS racing...and with a 6000 RPM redline, you should get many years of good service. These engines were engineered by factory engineers, who know more than we give them credit for. Every engine is a compromise, no matter who builds it. For the street, lean toward conservatism and you can't go wrong. Good luck.
Old 04-16-2006, 04:15 PM
Originally Posted by ZOERA-SC7XX
Crate engine is best unless you're doing SERIOUS racing........
Hhmmm.....best to talk to RacerX#99, who occasionally checks in here...he had a (I think) 392 crate motor that he ran the b*lls off of, open-tracking same for about 3 years. Has said himself that was probably the best motor he's had in the car.
And you are right about the lack of credit given to the factory; without them, ALL of the custom builders would have to look elsewhere for a vocation.
Old 04-16-2006, 04:53 PM
Actually, you can build a motor with all aftermarket parts. I believe the increasingly common 427FEs are largely these. As are many race versions using Dart or World blocks.
That is not to say that the Ford crate motors are bad. Especially the inexpensive ones fill a void not otherwise filled. However, aftermarket engines also fill some voids.
Old 04-16-2006, 05:08 PM
mrmustang's Avatar
Gold Star Contributor
Exclamation
David,
1: An FE (390,428,427) is not a common engine to just stumble across
2: If your thinking about whether to build an engine yourself or buy a Ford crate engine, stick with the Ford crate engine.
Enough said.
Bill S.
Old 04-16-2006, 08:07 PM
Cashburn's Avatar
Backdraft Racing Dealer
Originally Posted by mrmustang
David,
Enough said.
Bill S.
I believe he means that builders are increasingly using aftermarket blocks etc.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 04-17-2006, 03:55 AM
Yes, indeed you can; in fact, if you were so driven, you could fabricate patterns and cast parts yourself; antique restorers do it all the time. But the fact is that the overwhelming majority of the aftermarket engine builders' product is built on a factory part.
Those of us with a touch less time find that factory parts are readily available, adequate to the job in nearly every circumstance, far cheaper than trying to do it ourselves, and a practical means to an end.
Dart/World/Fontana parts all have their origins in what the manufacturers started. Without the factories they would be nice thoughts. Doubtless you remember the DFV Fords, David - just another factory engine too. Kinda put Colin Chapman on top of the world.
Point being that anything can be done; just that most of us find factory stuff to be a much better starting point. Evolution of our needs/wants will always progress.
Old 04-16-2006, 11:38 AM
Cobra Make, Engine: Superformance #1048, 392w
although new to me - my stock 392 has 6800miles and layed down ~460hp (15% loss /w 390rw) on the dyno - seems to be plenty happy /w no problems. I've heard something about some of the 392s having issues with the type of pistons used - maybe someone has more info.
Old 04-17-2006, 04:05 AM
427SnakeSC's Avatar
Are there still pistons and rings available for the stock 427 SO bore?
Old 04-17-2006, 04:21 AM
In a word, yes.
If you mean are original 60's vintage Ford parts available, well, maybe you could find some, someplace.
However, there are enormously better parts available now from just about any piston mfgr. Stock sizes or otherwise.
Old 04-17-2006, 07:13 AM
I should have said that mine (the one that came up with a cracked block) was one of the "newer" ones with a warranty (12 month / 12,000 miles...I think). That's why they fixed it. Also, Reg offered to do the removal / reinstallation for free but I had to get the car to him.
Overall, not a bad outcome. If I'd have had more room in my garage I would have done the engine removal / reinstallation myself and it wouldn't have cost me anything...except a little time.
Rate This Thread:
