December 2025
Old 07-03-2006, 03:50 PM
Cobra Make, Engine: Backdraft #172
Default More HP
Just wounded what the general feeling was on getting more HP.I have a crate 351, 385 HP, and would like a little more hp, I have a $2500 to spend and want to spend it wisely.Porting the heads has been metioned, replacing the heads, blower which for some reason I lean away from, stroker kit?
Let me know
Cheers Tonyd
Tonyd "kiwi" living in the USA
Old 07-03-2006, 05:02 PM
LMH's Avatar
LMH LMH is offline
Depends on what heads you have but my opnion would be stroke to 408 and porting.
Old 07-03-2006, 06:55 PM
wtm442's Avatar
Beam Me Up Scottie
Biggest bang for the bucks spent:
1) Dyno Tune
2) Get rid of restrictive side exhaust
3) Higher numerical rear gears
4) Nitrous
5) Head/Cam work
Warren
Old 07-03-2006, 07:24 PM
Power comes from your top end. Heads and cam.
I would have head work done....and change the cam.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 07-03-2006, 08:00 PM
Dwight's Avatar
Default More Ponies
Heads, Keith Craft / Edelbrock
cam and intake, recommended by Keith Craft
gears, tires, dyno tune
408 stroker kit are $1700 + - but it will take about $7000 to $8000 total to build the motor. If you have the water pump, oil pan, distributor, MSD, etc you can save a few bucks.
Dwight
Old 07-03-2006, 08:29 PM
hssss's Avatar
It all depends on your usage and the level of your mechanical ability. The path I'm taking light chassis foremost. The engine will be a roller 96 block that the level of machine work will depend on the damage I find from a broken piston. the rotating assembly will be a 3.85 stroker which at 30 over produces a 392 composed of rebuilt and beam polished 351 rods, and 302 forged pistons. The heads will probably be Twisted wedge CNC 205s and use a fairly aggressive cam. This should result in around 500+ hp and I assure you I will have nowhere near 7k in it. I personally would not go bigger than this with a 351 since you start to get into expensive machine work and the rod/stroke ratio degenerates.
Old 07-03-2006, 10:30 PM
Cobra Make, Engine: BDR 302 AFR 165
Heads, Cam, and a 150 shot of spray. I would do AFR 185's 58cc from Ed Curtis and get a custom cam from him. Go to the dyno and tune it all.
later
dennis
