Old 09-04-2006, 08:17 AM
Cobra Make, Engine: B&B 302 GT40, T5 5sp, 9"rear end
Default Throttle cable bracket
I have a 302 with a edelbrock manifold and carb I cant find the bracket that bolts to the manifold and hold the cable any ideas? The car is a B&B and Im using their recommended cable..
Thanks!
Old 09-04-2006, 10:17 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Is it the Lokar, through the firewall braided bracket and cable setup or something just like it?
They generally have the bracket included and may mess with your mind as it does NOT bolt where the 302 has it's backet.
The Lokar and many aftermarket cables setups bolt the bracket to the back of the carb over ( or under ) the two rear bolts. Or just the bolt on the left rear, depending. Then you run the two springs to the throttle and the bracket.
Hope this helps.
Old 09-04-2006, 10:49 AM
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
I ran my cable to the front of the carb and used the bracket that came with the cable, see my photos
PapaJohn
Old 09-17-2006, 07:14 AM
Rick Parker's Avatar
In my gallery is a photo (click on it to enlarge) of my engine. The throttle cable bracket was easily made from stainless. It has a set screw to retain the outer cable and a corner piece welded on the bottom to keep it from rotating.
