LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-23-2006, 06:29 PM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default Max RPM's on a crate 302 345 hp
need help, got a Ford crate 302 345 hp engine with 670 CFM Holley...what would be the recommended RPM limit? 6000...6500?
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
Old 10-23-2006, 06:36 PM
Cobra Make, Engine: BDR 302 AFR 165
Probably less than 6200 rpm if it is a hyd roller cam.
later
dennis
Old 10-24-2006, 08:48 AM
I would stay under 6,200 RPM unless you change the valve springs to something like the Comp Cams beehives.
Kevin
Old 10-24-2006, 09:04 AM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Just a thought - at 6000 RPM every piston is going up and down 100 times per second. At 19,000 RPM (Formula 1) they go up and down 317 times per second, why turn off the spark! This may be the reason engines tend to break at high RPM while they will run forever at 2,500 RPM.
Bob
Old 10-24-2006, 09:31 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Put a 5800-6k limiter chip in the box. With that engine you could probably hit 7k no problem every gear...for a limited period then something will let loose. Smallblocks scream and keep on winding up.... it's real hard not to keep your foot into it before you shift.
That Ford crate 345 has hyd lifters unless you optioned solids ...over 6200 the lifters are working far harder than they were designed to even with roller rockers.
Been there, done that ,paid the price, not once but twice...keep the rpm at 6k or under.
MOO
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 10-25-2006, 04:08 AM
Cobra Make, Engine: Unique 427SC/331/5 forward
Call Ford Motorsport and they'll tell you that the B cam has signed off by 6000 rpm. Not much point in running it past there.
Old 11-06-2006, 01:11 PM
I do not know what cam is in this motor but look into the specs. The motor may very well spin to the moon but if the cam is done making power by 5800-6000 rpm then there is NO use in spinning faster.
You can't make anything everything proof, so have fun and be careful.
