Old 08-29-2007, 08:37 PM
rattlesnakepete's Avatar
Cobra Make, Engine: Lonestar 427 Comp. 351W
Default Dip stick pops out of tube at 5000+ rpm
I have been wrestling with a proplexing problem with my windsor. My engine is built for 2000 to 6000 rpm. The dip stick will pop out of the tube ( front cover 1969 model) when the motor sees 5000 or more rpm. This can make somewhat of a mess in my engine compartment.
I have a Canton 9 qt. road race pan/windage tray/ pick/ crank scraper kit.
I run 8 1/2 qts of oil total/
Big KN stlye valve cover breather on one side and a free working PCV hooked to manifold vacuum on the other cover. I have confirmed the proper function of both.
The dip stick fits plent tight in the tube.
I do not know if this is crank case pressure or oil impingining of the dip stick that causes it to pop out like this.
Any experiences or ideas of what could be wrong?
Way to go Roscoe
Old 08-29-2007, 08:51 PM
xlr8or's Avatar
how much does the dipstick tube and handle wiggle if you just rev it up in neutral? Could just be vibrating out if it's not a crankcase pressure problem.
Old 08-29-2007, 08:55 PM
wtm442's Avatar
Beam Me Up Scottie
Mine does the same thing. It pops out about 3/4 to 1 inch max. But I'm not sure at what RPM it pops out. I would assume its crankcase pressure. But no oil comes out of the dipstick on mine.
Warren
Old 08-29-2007, 09:13 PM
kris-kincaid's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to kris-kincaid Send a message via Skype™ to kris-kincaid
I had a '66 Mustang with a worn out 200 six in it that did the same thing. I fixed it by using lockwire to hold it down, then the PCV valve started doing it so I lockwired it down too. Problem solved!
Old 08-29-2007, 10:27 PM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
Grab an old plug lead boot -Plug end - Straight type. Force this over the end of the dip stick & refit so that it becomes a seal & retainer. Its a harmonic thing that sets up in the dipstick and it just vibrates out at those RPM's. Just another lack of thought @ the design stage on fords part , the oil being flung of the timing chain is aimed straight at the dipstick tube and any crankcase pressure tends to carry it up the tube. If they had fitted the dipstick on the other side of the timing cover or in the pan like some other models it doesnt seem to happen.
Jac Mac
Old 08-30-2007, 04:05 AM
Might not be a bad idea to run compression and leakdown. Maybe your engine is sending you a message.
Old 08-30-2007, 05:22 AM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Is the dip stick tube in the stock location, or in the canton pan?
In the stock location, I had the stick curling under and making contact with the stroker crank, popping the stick out of the tube. I moved it to the pan, and problem solved.
Old 08-30-2007, 05:31 AM
John McMahon's Avatar
Cobra Make, Engine: SOLD: 2013 Boss 302 Mustang #2775 (both options). SOLD: 95 Mustang Cobra R #4 of 250 "Rosie's Diner" car. SOLD: CCX2-2505, #5 of 7 289 FIAs ever produced at Contemporary! my first Cobra: Unique 427SC w/ 428CJ moder!
Thumbs up
can be fixed using an insulated clamp and a spring.
Secure the clamp on the tube with an eyelet to put the spring through. Attach the spring to the dipstick. The spring is easily detached when you need to check oil levels. I had this setup on my last two race cars and had no problem.
REMEMBER....In Case of Spin....Both Feet in!!!!!
Old 08-30-2007, 10:27 AM
rdorman's Avatar
Renegade Nuns on Wheels
Do just to be sure. Make sure the PCV hose doesn't collapse either. Otherwise, I used the spring method
OhioCobraClub.com
LondonCobraShow.com
Old 08-30-2007, 09:58 AM
bobcowan's Avatar
The problem is that you're building up a lot of crank case pressure. That pressure has to go somewhere, and will find the weakest point.
You can attach and seal the dipstick better. But then it's not the weakest point. That pressure will blow out of somewhere else - like the rear main seal.
Old 08-30-2007, 04:28 PM
Take 1 1/2 to two quarts of oil out and then run 5000. You don't need 8 1/2 qts in there. Yes, you've got a scraper, tray and baffled chambers. I've run 7 in my same Canton in a sideoiler for 16 years.
Barring other issues we don't know about, that should stop your problem and won't hurt the engine-even in track use.
Chas.
Old 08-30-2007, 06:10 PM
CHANMADD's Avatar
I keep my dipstick in the trunk and plug the tube with (Brake nipple cover) a rubber pushed in. My worry was that I had seen the dipstick tube move and then the stick get's caught up in the crank,nnot cool!!
Old 08-31-2007, 05:35 PM
JayBar's Avatar
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
I was having a problem with oil coming out the breather with my set up.
I had a canton 7 qt pan remote filter and oil cooler and was running 8.5 qts. Canton told me the 7 gts included the filter, so I added 3/4 qt for the cooler, and now all is well.
JayB
Jupiter, FL
Old 08-31-2007, 06:55 PM
Smile
A wealth of information and sound advice from all of you good fellows.
Thanks a bunch for your input!
Way to go Roscoe
Old 08-31-2007, 09:01 PM
Cobra Make, Engine: FFR, 302, Mas-Flo
Sounds like bobcowan has it right. If you secure the dipstick in the tube,
the pressure will go elsewhere.
Old 08-31-2007, 11:45 PM
CHANMADD's Avatar
Make sure that your valve covers have a baffle under both breather and PCV openings.That caused me the same problems that you are having.
