01-31-2007, 07:59 AM
He
Cobra Make, Engine: Actual car: AC Autokraft MK IV with Keith Craft 331. Gone: Home built Crendon, original style twin tube frame, powder coated, stainless sidepipes. FE 433
Cleveland Rebuild starting now
Hi all,
i'm stopped my plans switching from 351C to FE for a Year, going now to rebuild my Cleveland and have some Questions about.
The new cam:mech roller Crane #528371
New lifters are:mech roller, Crane Ultra Pro #44570-16
Cam Timing is: TAPPET @.020
Lift: Opens Closes ADV Duration
Intake 39 BTDC 65 ABDC 284 °
Exhaust 80 BBDC 34 ATDC 294 °
Crane strongly recommends NOT to use restrictors as they are in now.
Is anybody running mech roller lifters with restrictors in a Cleveland, made some experiances about that topic?
Are you guys interested in a pictured build report ??
Westcott
Everything should be as simple as possible - but not simpler !!
01-31-2007, 09:38 AM
UT
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Build photos of your progress would be great!!
Sorry I do not know anything about a Cleveland!!
Terry
01-31-2007, 05:30 PM
OH
Cobra Make, Engine: Shell Valley- 390 FE, 4 speed toploader, 3.50's
Hey Terry! Westcott- I would be interested in the build as well. My first car was powered by a 351C, and it was the first engine I rebuilt. Even with the 2bbl heads, it never ceased to amaze me- especially what I put it through. Again, id like to see some build info and pics!
Greg
03-18-2007, 06:36 AM
He
On hold.............
My project is on hold because of the spare parts delivery time, sorry!
I'd like getting all the needed spares before the complete disassembly.
Parts i'm waiting for:
-#MOR-20558 Moroso kicked out front sump oil pan, 7quart
-#MOR-24558 Moroso pickup
-#CRN-52970-1 steel crane distributor gear
-#ARP-154-2501 balancer bolt kit
-#MRG-2663 O-RING WATER NECK FORD 351C
-#SES-5-65-04-201 TIMING COVER 351C/M 400M
Estimated delivery date from summit is April, 4th.
The moroso oil pan was necessary after a Canton pan and pickup auction on ebay wasn't that succesfully..........  Paid for the part and delivery but nothing happend, dispute is still open.
On the other hand i'm waiting for Crane distributor spare parts for my 1000-1605 high performance distributor.
Since last year, after a distributor rotor failure caused ignition module damage, i'm still waiting for the module, cap and rotor !!!!
Crane customer service promised sending the parts next month, this was in August 2006
Delivered parts from summit, waiting on the bench:
-New taylor spiral pro silicon ignition cables
-New set of engine gaskets
-#CRN-44570-16 Crane ultra pro mech. roller lifters
-#CRN-528371 Crane mech. roller cam, RPM 3200-7200; Adv. Dur. 284 Int./294 Exh.; Valve Lift .560 Int./.585 Exh.;
-#PTP-6-503 Prothane polyurethane motor mounts
-#SLP-224-41166V Sealed power HV oil pump
The pushrods length will be defined during assembly because here in Germany experienced cleveland bilders availlability is going to zero
Old parts to be used as carry over:
- CS Shelby Valve covers
- 4-bolt CJ block
- Restrictor kit
- External oil support line
- Complete engine screw set 12-point stainless from ARP
- ARP bolts for heads and mains
- Edelbrock water pump
- Edelbrock modified dual plane intake with removable divider wall insert
- Modified FE expansion tank to fit the Cleveland
- Eagle H-Beam rods, domed, for higher CR, 11:1
- 2V open chamber heads, ported and reworked for roller rockers
- Scorpion roller rockers
- Manley Chevy valves
- Guide plates
- External oil cooler
- Turkey pan,
- #FMS-M-9600-R302, Ford Racing small oval air cleaner(L: 11.875 in., W: 8.375 in.)
set up with 2.5 in. filter
Again, sorry for my bad english writing.
I'll keep you updated,
Westcott
PS: In the meantime i changed my radiator setup to the more original angled position with cover on top and center clip fixation, twin blowers in front.
03-18-2007, 03:05 PM
Oh
Westcott - I'm looking forward to your build with pictures.
Having been to Germany and France about 6 times, I would like to assure you that your english is pretty darn good. You guys are always saying your english is not very good, but it is more than enough to communicate well.
03-18-2007, 05:20 PM
Great looking car!
I was just discussing the build up of a 351C with a friend tonight. A 500hp 408C would be a powerhouse and still allow the use of our current headers, pipes etc.....not to mention the weight savings.
Keep us all posted with gallery pics.
Best to you and the build,
Jeff
03-18-2007, 06:09 PM
KY
Are the lifters pressure fed lifters?
03-19-2007, 12:29 AM
He
Blykins,
what do you mean by pressure fed?
Crane strongly recommends not to use restrictors, but the instructions look like universal for all crane lifters.
I'll give them a call today.
Westcott
03-19-2007, 03:03 AM
KY
Some new solid roller lifters have an orifice to pressure feed the bearings. Comp Cam's lifters are like that and I used them in my FE.
05-02-2007, 10:36 AM
He
O.K. all the missing parts are here:
- NEW  Cleveland Timing Cover from Summit Racing !!!
- Moroso Front Sump Pan, kicked out with Moroso PU
- New Sealed Power HV Oilpump
- New Centerforce dual friction Clutch
- New Pilot Bearing
- New Crane Racing Distributor
All other replacement parts are sitting on the shelf since February.
Tomorrow i'm going to dismantle and hot tank the engine. I'll take some pics and show them here together with some build up progress infos.
See you, Westcott
05-04-2007, 10:56 AM
He
First 2 days are over, what i did:
- dismantle the block
- found some small debris outside on the #2 and # 5 piston walls
- turn out all restrictors
- throw out all bearings
- cleaned all removed parts and stored them
- check overall for cracks- no cracks
- check all cylinder bores:
+ 2 bores, #2 and #6 had small scratches, must be from some lifter and cam debris carried from the pistons up and down
+ decided not to hone them but to brake the lines.
- on all other bores you can see still the criss cross pattern from the machining 2 years before
- checked all lifter bores, trimmed the sharp edges where the lifter galleys go through,
- honed all lifter bores after trimming the edges
What to order and to replace:
- all rod bearings
- all cam bearings
- main bearings can be kept
This an first overview with all the main parts off:
05-04-2007, 11:00 AM
He
as you can see we had some fun stuff sitting beside......
05-04-2007, 11:02 AM
He
here you can see the scratches in #2 and #6
http://www.clubcobra.com/photopost/s...0&ppuser=21156
Every pic will be found in my gallery bigger and with better resolution until the job is done
05-04-2007, 11:43 AM
NJ
Cobra Make, Engine: West Coast Cobra, 427SO 2x4's, 630HP/600TQ
Hi Westcott:
I used to race a Cleveland in my Cobra before I switched to the FE. I like the Clevelands and you can get them to wind up really fast with the right heads. I can't see the scratches in your cyclinders although the cross hatch on the walls looks good. If the scratches are vertical in the cylinder then i wouldn't pay any attention to them. You would be shocked if you saw the way they come from the factory; especially GM blocks. If you have a close up of the cylinder i would lke to to see it. I will email you pictures of successful motor with scores and pits in the cylinders. Contrary to the old grandfather tales; it's no big deal as long as they are vertical.
Westcott; i would like to ask you some questions about Germany. My parents are from Solingen and have both recently died. I will send you a PM, so please check your mail box later .
If i can be of any help to you getting 351C parts, please let me know. I just sold a 9 second 351C motor; Boss 302 heads; Weiand Tunnel Ram and twin 850 double pumpers last week. It was in a 1964 Falcon but we are putting a 427FE in it this summer. I have a racing friend that we share the car together which makes it a little easier and safer. All it takes is money and time to keep it going.
Bernd
"Shut up and take the pain".
05-07-2007, 07:13 AM
Renegade Nuns on Wheels
Oh
For that motor... may I strongly suggest a Parker Funnelweb and not the edelbrock if you have the hood clearence.
05-07-2007, 11:16 AM
He
Rick, how much higer is the Parker Funnelweb against the Edelbrock ??
Uwe
05-07-2007, 11:20 AM
Oh
Not sure which edelbrock you have nor its height. The funnelweb is 6 7/8" (above the rail on the block) and their website is http://parkerracing.com.au/funnelweb.html . They are really good with the cleveland you may want to make contact with them. I think any dual plane (including a modified one) may be to mild for that motor and cam combination. Sounds like you are building a 500hp screamer!
05-07-2007, 11:47 AM
Member of the north
Cobra Make, Engine: A Cobra
Well, I'll toss in a few suggestions. I run a Cleveland I like to wind up.
Ford's biggest mistake on the Cleveland was the oiling system. Known fact, there are a number of ways to combat it.
Melings ( spell it right when you worder it ) HVHP oil pump is a must.
Tap and install .100 restrictors across the three middle jounals and do the end the same way but with two restrictors. Then align hone the block with the restrictors out.
Do whatever else machine work you are going to do to the block at this time. Make sure the second or third web/journal is not cracked ( this happens ).
Wash it twice and install those restrictors with loc tite.
I would balance the entire rotating assembly.
Install rotating mass into block. I would use ARP studs and nuts.
If you go to 8 qrts, use the Canton road race and their pickup for the oil pump.
Use a billet steel oil pump drive ( the ford ones twist up ).
I would either buy, get or make a set of boss 351 heads with adjustable valve train. Yeah, I know, they breath too much for the street. Hey, do what you want.
Use the Crane gold roller rockers.
Run the Oil balance line from the front of the engine to the rear. There is a port next to the oil filter. Thread a nipple into the port and run a hard line to the rear of the block where the oil pressure sending unit goes. 3/8 Stainless works nice and will help with the oiling problems.
I like the Torqer ( try to spell this one correctly ) intake, it flows okay and doesn't cost a fortune.
I like the 3310 for a carb with a few tuning items.
You should have a smooth running Cleveland that will wind up nicely.
05-07-2007, 11:53 AM
Member of the north
05-07-2007, 11:58 AM
Oh
Originally Posted by trularin
Shssssssssssshhhh... I get a kick back  Funnel web versus Torqer is like stock 2 barrel versus Torqer  Actually, Edelbrock now has a performer RPM that works with the 2v heads but that cam I think is still too strong for the RPM manifold. His heads have been modified to be adjustable so he should be fine. The ausie closed chamber 2v would be a better choice but since he has them, spent money on them and bought the pistons I didn't want to send him back to square one. Of course CHI's would be even better yet
